how to use setFields to set the water velocity only (two phases) at inlet |
December 28, 2015, 12:18 |
Yage
Rep Power: 11 |
I would like to set the U boundary for the water phase only. so which topoSetSource type should I use and how to set it up? Regards, Yage |
December 28, 2015, 12:33 |
Yage
Rep Power: 11 |
Update:
I solve this by using boxtoFace to set a box "in front of" the inlet boundary so that only inlet boundary is re-defined. Regards, Yage |
May 9, 2017, 04:02 |
please upload your code to set velocity using BOXto FACE
sandy
Rep Power: 10 |
Pressure Inlet VS velocity Inlet difference | Mohsin | FLUENT | 9 | January 4, 2021 10:34 |
3-D parabolic velocity Inlet - Steady state - UDF Turbulent Flow | mohibanwar | Fluent UDF and Scheme Programming | 10 | May 18, 2015 10:34 |
How to define a fixed velocity for a given mass flow rate on inlet | mqasimali | FLUENT | 2 | April 12, 2013 17:24 |
udf inlet velocity is not set correctly, why ? | GaoGe | FLUENT | 0 | June 17, 2008 08:33 |
How to set pressure & velocity in inlet B.C??? | asghari | FLUENT | 2 | February 7, 2007 08:00 |
