how to define patches for each surface on a solid structure
Old   February 5, 2016, 04:04
Default how to define patches for each surface on a solid structure
Yage
Yage is on a distinguished road
Dear All,
My solid structures are input from a stl file and it has only one patch name,
but I would like to separate this single patch or define new patches on, such as a cylinder shape column, the top and bottom faces.
I would like to do this because I need different boundary conditions for each surface.
Regards,
Yage
Yage is offline   Reply With Quote
Old   February 5, 2016, 13:27
Nima Samkhaniani
nimasam is on a distinguished road
the easiest way is to use salome to decompose faces and then regroup them as different boundary patch name
you can download salome from here
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   February 6, 2016, 04:30
Yage
Thanks for the reply.
So the salome can decompose the stl structure and rename each faces?
Regards,
Yage
HELP----Surface Reaction UDF Ashi Fluent UDF and Scheme Programming 1 May 19, 2020 21:13
UDF carbon conversion papteo Fluent UDF and Scheme Programming 1 August 18, 2011 07:32
UDF Scalar Code: HT 1 Greg Perkins FLUENT 8 October 20, 2000 12:40
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 13, 2000 23:03
UDFs for Scalar Eqn - Fluid/Solid HT Greg Perkins FLUENT 0 October 11, 2000 03:43
