Home > Forums > OpenFOAM Pre-Processing
boundary conditions for turbulence model
Old   February 5, 2016, 05:34
Default boundary conditions for turbulence model
Yage
Yage is on a distinguished road
Dear All,
I would like to know the boundary conditions for k-omega model.
1. is there any scalable wall function in OpenFOAM?
My y+ values vary from 1 to 10.
According to the guidance http://www.dicat.unige.it/guerrero/o...turbulence.pdf
For 1<y+<300, use kqRWall and omegaWall function, and k wall value is set to be 0 and omega wall is set to be 10x6xnu/(0.075y^2)=51200 for my case.
The internalfield and other boundaries for k=3/2(UI)^2=0.04
and omega=(rho.k/mu).(mut/mu)^(-1)=400
Please help me check if these boundary conditions are reasonable.
And this is a problem: the k value at wall will change to 0.04 (internalfield value) after decompose to avoid crash. (OpenFOAM 2.3.0). and due to my experience, all other non-zero k wall value will also change to internalfield value, which confused me.
2. I further refined my mesh to y+=1~2 so that I dont need wall function, then which boundary condition should I use?
I tried fixedValue with 1e-10, but the simulation got a bounding k issue after several timestep and the pressure force on wall is extremely high. I used celllimited linear upwind for k and omega
So I have no idea how to solve this problem
Thanks in advance for your suggestion.
Regards,
Yage
Yage is offline   Reply With Quote
Thread Tools
Trackbacks are On
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Problem with SIMPLEC-like finite volume channel flow boundary conditions ghobold Main CFD Forum 3 June 15, 2015 11:14
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 06:28
RPM in Wind Turbine Pankaj CFX 9 November 23, 2009 05:05
Water vapour condensation in CFX-5.7.1 hdj CFX 1 November 27, 2005 08:15
