Home > Forums > OpenFOAM Pre-Processing
Which parameters to keep same for a simplified model
Old   February 5, 2016, 11:42
Default Which parameters to keep same for a simplified model
Vineet Bhola
vineet_bhola is on a distinguished road
Hi Guys,
I am investigating a flow geometry including heat transfer using a simplified geometry. I do that to make the calculation faster as well as it is easier to pint out the issues in a simple geometry.
My concern is as the dimensions change when a build a smaller and simpler model, which parameters should I keep constant?
I am guessing average Reynolds number, inlet temperatures etc. I also found something about "Yplus" parameter. But Openfoam provides min, max and average value every patch if I use the command
yPlusRAS.
Which value should I compare, maximum OR average.
Also please let me know any other parameter which I should keep the same.
Thanks
Vineet
vineet_bhola is offline   Reply With Quote
Thread Tools
Trackbacks are On
Use of k-epsilon and k-omega Models Jade M Main CFD Forum 13 June 24, 2016 11:57
Error in Two phase (condensation) modeling adilsyyed CFX 15 June 24, 2015 19:42
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 06:36
coalChemistryFoam: "Foam::error::printStack(Foam::Ostream&) at ??:?" musabai OpenFOAM Running, Solving & CFD 2 February 20, 2015 15:07
About the solution of a simplified two-phase model maximus Main CFD Forum 3 October 25, 2005 12:03
