March 3, 2016, 21:58 |
Defining 1D heat source in OpenFoam
Shahil
Rep Power: 10 |
I am working on a problem, where there is a heat source at the centre of the 2D box (cube with Z = 1mm). Can anybody please help me define a one-dimensional line heat source (line made by joining two vertices). Given the size of the box = 400 x 600 x 1 (mm), the heat source of length 50mm is placed at the centre with y=0, z=0. I learned how to specify a box using boxToCell, but is there a way to specify a 1D line in topoSetDict ? Please help me with the code. |
OpenFOAM v3.0+ ?? | SBusch | OpenFOAM | 22 | December 26, 2016 14:24 |
[Other] How to use finite area method in official OpenFOAM 2.2.0? | Detian Liu | OpenFOAM Meshing & Mesh Conversion | 4 | November 3, 2015 03:04 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
[Other] Adding solvers from DensityBasedTurbo to foam-extend 3.0 | Seroga | OpenFOAM Community Contributions | 9 | June 12, 2015 17:18 |
[swak4Foam] swak4Foam-groovyBC build problem | zxj160 | OpenFOAM Community Contributions | 18 | July 30, 2013 13:14 |
