boundaryField on outlet for a non fully developed flow ? |
March 25, 2016, 09:11 |
AdOo
Rep Power: 10 |
Hi all,
What type would you choose for the outlet boundaryField on U with a flow non fully developed ? Because, I can't use zeroGradient ( neither inletOut which is much like zeroGradient if I've understand...). In my case I'm want to simulate a turbulent and incompressible flow in a pipe. I will set:
March 30, 2016, 10:02 |
AdOo
Rep Power: 10 |
No one ?
Should I post my question elsewhere on the forum ? |
March 30, 2016, 10:27 |
Joachim Herb
Rep Power: 21 |
Perhaps fixedMeanFvPatchField does what you are looking for:
https://github.com/OpenFOAM/OpenFOAM...FvPatchField.H It allows different values for the different faces of the surface, but fixes the mean value. The mean value is calculated by weighting the different face values with the size of each face. Perhaps you have to modify the boundary condition sum up the fluxes of the faces and fix that value. Still, you can only set the velocity on one face (if you have only two non-wall boundaries). Then your inlet should probably be set to zeroGradient. But why does zeroGradient for U on the outlet not work? You could also try this (zeroGradient for U) together with fixedMeanFvPatchField for the pressure on the outlet and fixedValue for U on the inlet. |
April 4, 2016, 03:43 |
AdOo
Rep Power: 10 |
I've seen an interesting post which helped me.
Here it is if someone need it too one day. http://www.cfd-online.com/Forums/ope...tvelocity.html Have a nice project, Adrien |
getting difficulties in developing fully developed flow through pipe.by openFoam | abhishek nandan | OpenFOAM Running, Solving & CFD | 2 | November 17, 2016 02:18 |
How apply pressure gradient to get fully developed flow? | nihossain | FLUENT | 0 | November 5, 2011 15:20 |
Fully developed flow in Star-cd | SMM | STAR-CD | 3 | September 9, 2011 15:54 |
Fully Developed Flow in Star-cd | SMM | STAR-CD | 0 | September 5, 2011 22:08 |
Fully developed flow profile | icfd | Main CFD Forum | 3 | May 20, 2009 22:21 |
