Home > Forums > OpenFOAM Pre-Processing
How to define a dependent boundary condition
Old   June 15, 2016, 10:29
Default How to define a dependent boundary condition
Laurent DASTUGUE
laurentD is on a distinguished road
i would like to define a boundary condition which is dependent of a quantity which is not the time (but the inlet velocity).
To be clear, i am currently using externalWallHeatFluxTemperature boundary condition and i would like to use a value of h calculated by a function, from the value of the velocity on the inlet of my geometry (a sort of pipe).
Is there a way to use a function of this type or must i create a new boundary condition ?
I think i have to use the nonuniform option and the "include file" command but i don't see any examples of the use of such a function.
If you need more precision to answer this question, ask questions.
Thank you.
Laurent
laurentD is offline   Reply With Quote
Old   June 15, 2016, 13:29
Lightbulb
Hesam
rapierrz is on a distinguished road
Hi Laurent,
You can use groovyBC for this purpose.
rapierrz is offline   Reply With Quote
Old   June 16, 2016, 03:39
Laurent DASTUGUE
Thx a lot, i will take a look on it.
Laurent
Old   June 16, 2016, 04:14
Laurent DASTUGUE
So i have looked for informations related to groovyBC.
I have some questions to do what i want to do :
- Do i have to install groovyBC utility ? (i am using OF2.3.1)
- What about swak4Foam ?
- Is there anywhere a tutorial for this kind of boundary conditions (not in my OF files anyway) ?
Thanks everybody who spend some time to help me.
Laurent
Old   June 16, 2016, 04:28
Timm Severin
Astrodan is on a distinguished road
Just install swak4Foam, it includes groovyBC
Look at the openfoam wiki or just search the web, there are tons of presentations describing the topic.
For specific help I fear an actual example (just try to use the BC and see what happens) would be useful.
Astrodan is offline   Reply With Quote
Old   June 17, 2016, 08:22
Laurent DASTUGUE
I have installed swak4Foam, following the commands given by :
https://openfoamwiki.net/index.php/I...tion/swak4Foam
Now i will try to use it to define the value of the h convection coefficient by a function (or a table depending on another quantity which is the velocity on a specific region).
When i look availables examples, the BC used is : groovyBC. For example :
   atmosphere
type            groovyBC;
variables "r1=0.25*(max(pts().x)-min(pts().x));r2=r1*0.2*(1-0.5*cos(54*time()));";
valueExpression "(sqrt(pow(pos().x-r1*sin(10*time()),2)+pow(pos().z-r1*cos(15*time()),2))<r2) ? 1 : 0";
value           uniform 0;
In my case i want to use the externalWallHeatFluxTemperature one, with a manual expression for the value of h. My next question is the following :
Can i use the externalWallHeatFluxTemperature linked with the groovyBC ?
Or:
Do i have to extract expressions used by externalWallHeatFluxTemperature and construct a new one with the changes i want ?
Thanks a lot.
Laurent
Old   June 17, 2016, 08:32
Timm Severin
First a small sugesstion, what is rarely shown, but makes things a lot easier to read, reformat the variables section so you can have one variable per line:
atmosphere
    type            groovyBC;
    variables
        "r1=0.25*(max(pts().x)-min(pts().x));"
        "r2=r1*0.2*(1-0.5*cos(54*time()));"
    value           uniform 0;
For your special purpose I believe you cannot use an existing BC directly, at least that's from I take from this post. So you will probably have to copy the expression used in the BC; however, this should not be too difficult.
Alternatively use any textbook on heat transfer (or you knowledge) to specify a suitable equation yourself. Reading the C++ code can be confusing if you're not used to it.
Old   June 17, 2016, 08:57
Laurent DASTUGUE
Thank you for the tip, it is very easier to read.
Yes it seems not so difficult, but it was a good thing to verify if there exists a faster way to do. I will try to do that.
Another question : Can i use a function name or a function number for the expression of a variable (h in my case) and fill the function in another file (with a include file i suppose) ?
Last one (for the moment) : Can i use a tabular in place of the expression, with for example a value of h depending on the value of Uinlet ? In this case, the tabular can be written in another file.
Thanks for your time.
Old   June 17, 2016, 11:39
Timm Severin
No clue, but I guess the #include directive works as before.
Groovy BC for lookup Table values
Old   June 20, 2016, 06:39
Laurent DASTUGUE
I have read the topic you have indicated to me. It is very useful thank you very much.
Only one thing is still a problem.
Can i use groovyBC but with a lookuptables for a variable and not for the main field ?
For example, in the case :
ailetteFace
         type            groovyBC;
         variables     ("hBC=50.0;"
                        "Ta=20.0;"
                        "kBC=0.5;");
         valueExpression    "Ta";
         fractionExpression "1.0/(1.0 + kBC/(mag(delta())*hBC))";
         value           uniform 293.15;
i would like to apply a lookuptables to hBC. And i don't know if it is possible. It seems that i am not the first person to ask it but i don't find any answer...
Laurent
Old   June 20, 2016, 08:04
Laurent DASTUGUE
I think i am on the right road to my objective.
Doing this for example :
    ailetteFace
         type            groovyBC;
      variables          (//"hBC=50.0;"
                            "Ta=20.0;"
                            "kBC=0.5;");
         lookuptables (
               name data;
               outOfBounds clamp;
               fileName "$FOAM_CASE/data.data";
         fractionExpression "1.0/(1.0 + kBC/(mag(delta())*data(kBC)))";
and filling the file data.data with
    (0 0)
    (1 0.1)
    (3 0.1)
    (4 -0.1)
i think i have succeed to define hBC as a function of a value, which is defined by the tabular included in data.data.
Can anyone confirm it is the good way ?
(don't be affraid about the numerical values, it is completely crazy, i am just trying to build the boundary condition as i want for the moment. I will fulfill the good values and the good dependencies after.)
How can i verify that the value written on the tabular are read correctly ?
Thanks.
Laurent
Old   June 20, 2016, 08:24
Laurent DASTUGUE
    ailetteFace
         type            groovyBC;
                            "Ta=20.0;"
                            "kBC=0.5;");
         lookuptables (
               name data;
               outOfBounds clamp;
    (0 0)
    (1 0.1)
    (3 0.1)
    (4 -0.1)
Thanks.
Laurent
Thread Tools
Trackbacks are On
sliding mesh problem in CFX Saima CFX 45 September 22, 2015 10:53
Installing OF 1.6 on Mac OS X gschaider OpenFOAM Installation on Windows, Mac and other Unsupported Platforms 129 June 19, 2010 09:23
vorticity boundary condition bearcharge Main CFD Forum 0 May 14, 2010 11:32
Missing math.h header Travis FLUENT 4 January 15, 2009 12:48
Free surface boudary conditions with SOLA-VOF Fan Main CFD Forum 10 September 9, 2006 12:24
