surfaceFeatureExtract: extracted edges lie outside the surface |
June 15, 2016, 07:37 |
Marco
Rep Power: 9 |
Hello everyone,
I am working on the pre-processing for the flow simulation around an aircraft wing. I am using the tool surfaceFeatureExtract before running snappyHexMesh, but I get a weird result when I visualise the extracted edges with Paraview: they are at a distance from the .stl surface. *see attachment "Edge1"* Does anyone know what the cause of this problem can be? Could it possibly be simply an issue with Paraview that does not display the surfaces and edges correctly? |
June 15, 2016, 09:00 |
Marco
Rep Power: 9 |
SOLVED: It was due to a wrong view setting: Parallel projection must be ticked.
Display Modes | |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 10:42 |
[snappyHexMesh] No layers in a small gap | bobburnquist | OpenFOAM Meshing & Mesh Conversion | 6 | August 26, 2015 10:38 |
[snappyHexMesh] Snap Precision to a STL Surface | malaboss | OpenFOAM Meshing & Mesh Conversion | 16 | July 26, 2013 02:44 |
[CAD formats] how to call my .stl file in the terminal | izna | OpenFOAM Meshing & Mesh Conversion | 21 | July 9, 2013 17:17 |
Patran Volume Meshing | Deb | CFX | 19 | April 17, 2003 11:56 |
