Resolving the boudnay layer???
Old   July 14, 2016, 13:38
Default Resolving the boudnay layer???
tareqkh's Avatar
CFD
tareqkh is on a distinguished road
Hello All,
This is my first post in this forum, so I would really appreciate any clarification. The question is regarding the use of wall function as well as fixed value at the wall such as airfoil walls. My understanding through the use of the steady state solve simpleFoam is that if we wanted to resolve the boundary layer near the wall for approximate values of y+=1, we would set the boundary conditions at the wall with the following boundaries for kOmegaSST turbulence model;
For the turbulent kinetic energy k;
airfoil
        type            fixedValue;
        value           uniform 1e-10;
For the specific dissipation omega;
airfoil
        type            fixedValue;
        value           uniform 1e+10;
1e-10 at k means a value close to zero and 1e+10 means close to the infinity. While if our y+ value higher than 40, we would use the following for kOmegaSST;
airfoil
        type            kqRWallFunction;
        value           uniform value;
airfoil
        type            omegaWallFunction;
Therefore, when we use values of y+ < 10, the boundary condition at the wall for k is close to zero, whereas close to the infinity at the walls for omega. The opposite is true when y+ > 30, means wallfunctions are suitable to use. I was wondering if someone is aware of these boundary conditions and whether the mentioned above is correct or not.
Thanks in advance,
tareqkh is offline   Reply With Quote
Old   July 15, 2016, 05:40
Tom Fahner
tomf will become famous soon enoughtomf will become famous soon enough
Send a message via MSN to tomf Send a message via Skype™ to tomf
You can also use omegaWallFunction in case of near-wall-treatment.
tomf is offline   Reply With Quote
Old   July 17, 2016, 18:38
tareqkh's Avatar
CFD
Does omegaWallFunction work for y+ value <10 too?
Have you ever experienced using fixed value instead for y+ <10 (k and omega)?
Is my question addressed incorrectly?
Old   July 18, 2016, 03:52
Tom Fahner
Yes it does.
For k yes, for omega it probably could work, but the omegaWallFunction option gives better results.
Prismatic boundary layer KateEisenhower enGrid 5 September 15, 2015 07:48
Problems installing OpenFOAM 2.3.0, 1.6-ext and foam-extend 3.0 sam.ho OpenFOAM Installation 35 April 5, 2014 15:31
[snappyHexMesh] Boundary layer generation problems ivan_cozza OpenFOAM Meshing & Mesh Conversion 0 October 6, 2010 13:47
OpenFOAM with Cygwin kitchener OpenFOAM Installation 6 April 24, 2006 23:09
errors Fahad Main CFD Forum 0 March 23, 2004 13:20
