July 27, 2016, 06:18 |
How can I get velocities(U) near a boundary?
Lee Jung Hoo
Rep Power: 10 |
Hi, I need to get velocities near the bottom(boundary), and the values of velocities at the bottom(boundary) are zero due to non-slip condition.
So, I want to make a new boundary(surface) near the bottom(boundary), and extract velocities on the new boundary. Then, I want to arrange those values to certain file(e.g. alpha.water). Any comments regarding this will help me a lot. Additionally, Is it possible to set a volume(not surface) to a boundary? Thank you in advance..! |
July 27, 2016, 10:16 |
Rep Power: 11 |
I am not sure if i get your problem, but how about using a plane in sample or probing a plane while running the calculations? You have several options in which way your data on that sample surface could be saved (e.g. openFoam file format)
July 28, 2016, 10:43 |
Lee Jung Hoo
Rep Power: 10 |
Thank you for your reply, Henning.
Can I ask you a little bit more detailed question? I want to extract velocities at intervals of 10cm above the bottom(boundary) after one-time step, and then the morphology of bottom(boundary) is changed due to some calculation using the velocities over the bottom(boundary). Then velocities over the bottom are needed again in the next time step. This process is repeated during the whole calculations, and accordingly the morphology of bottom is changed on and on. Is it possible to get velocities and bring them to my solver at each time step using 'sampleDict' or other utilities?? Any ideas will help me a lot! Thanks!! |
July 29, 2016, 04:54 |
Rep Power: 11 |
You can try append this to your system/controlDict file to get the values (basically its like sampleDict but run during calculations - in this case at each time step):
functions { cuttingPlane { type surfaces; functionObjectLibs ( "libsampling.so" ); outputControl timeStep; outputInterval 1; surfaceFormat foamFile; // Select the format you want you data saved as fields ( p U k epsilon // values you want to extract ); interpolationScheme cellPoint; surfaces ( SurfaceName //Any name you want to give it { type cuttingPlane; planeType pointAndNormal; //Different options possible pointAndNormalDict { basePoint (0.5 0 0); //Point the plane should cut through normalVector (1 0 0); //Vector normal to plane } interpolate true; } ); } |
July 30, 2016, 00:03 |
Lee Jung Hoo
Rep Power: 10 |
Oh, that is what I want almost exactly! Thank you so much.
I would better check the libraries for sampling to know more about it. I'm sorry but.. I have some last questions. Can I extract velocities in certain volume as well as surface using the sampling in the whole domain? (e.g. from x=0, y=0, z=0 to x=3, y=3, z=3) And do you know an example or have any idea related to interaction between 'a solver' and 'result of post processing' at every time steps? It's because the extracted velocities have to be sent to 'my solver' at every time steps for mesh deformation. I'm very appreciative of your kind reply. Thanks a lot! |
August 1, 2016, 09:07 |
Rep Power: 11 |
Sorry, I haven't done that. Try to find out more about sampleDict settings. I would assume that it is the best bet for a volume, if its possible. Usually the Settings in control dict are more or less the same.
Regarding the interaction, you might want to look for Fluid-Structure-Interaction(FSI) examples. This is something i have not used as well, but as far as i know i requires a constant communication between solver and results. So that might be worth looking into. What are you trying to simulate anyway? |
August 3, 2016, 09:20 |
Lee Jung Hoo
Rep Power: 10 |
Thank you! I think your recommendations will really be helpful for my study.
I'v been trying to simulate bottom-current interaction and resulting scour on the bottom in a fluid. So, the mesh at the bottom must change slightly at every time steps. But I'm beginner in compiling, so I have had difficulty with building a solver for the simulation. I'm planning to learn how to compile a solver and how to modify functions(I'm beginner in c++ as well) in more detail. Thank you for your help. |
Display Modes | |
3D Windturbine simulation in SU2 | k.vimalakanthan | SU2 | 15 | October 12, 2023 05:53 |
Centrifugal fan | j0hnny | CFX | 13 | October 1, 2019 13:55 |
Low torque values on Screw Turbine | Shaun Waters | CFX | 34 | July 23, 2015 08:16 |
Implementation of boundary conditions for FVM | Tom | Main CFD Forum | 7 | August 26, 2014 05:58 |
GETVAR Error in Multiband Monte Carlo Radiation Simulation with Directional Source | silvan | CFX | 3 | June 16, 2014 09:49 |
