Creating a new case from command line
Like Tree1Likes
Old   April 17, 2007, 05:15
Default Hi, is there a command (I d
Gregoire Hanss
gregh is on a distinguished road
is there a command (I don't want to use the FoamX interface) to create automatically the directory tree and files needed for a new clean case (no mesh, I will convert it from a 3rd party soft, no solution, ...) ?
Thanks
Greg
gregh is offline   Reply With Quote
Old   May 19, 2007, 14:46
Default You can duplicate the original
Marco Moscaritolo
mavimo is on a distinguished road
You can duplicate the original case with:
cp -r /original/case /new/case
and after delete the mesh with
rm /new/case/constant/polyMesh/*
Bye
Mavimo
mavimo is offline   Reply With Quote
Old   October 8, 2008, 05:13
Default Hi, is there another way to
Michael
farbfilm is on a distinguished road
is there another way to create a new case from command line without copying an old case or tutorial cases???
I'm using OpenFoam1.5 and want to create a new case with a command that creates automatically the directory tree! Is that possible???
Thanks
farbfilm is offline   Reply With Quote
Old   October 8, 2008, 14:24
Default Hi, I have a template direc
Fabian Braennstroem
braennstroem is on a distinguished road
I have a template directory and use emacs/dired to create a new case with:
(defun opf_standard_0()
(interactive)
(dired-create-directory "0")
(dired "0")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/k" "k")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/omega" "omega")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/epsilon" "epsilon")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/R" "R")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/p" "p")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/U" "U")
(copy-file "/home/gcae504/SCR1/Software/Vorlagen/0/nuTilda" "nuTilda")
(revert-buffer)
(remember)
A simple menu can look like:
(easy-menu-define cfd-pre-menu dired-mode-map
"'org-mode' menu"
'("CFD-Pre"
["FLUENT Journals isotherm/stationaer" fluent_standard_journals_stationaer t]
["OpenFOAM New Case" opf_standard_simpleFoam t]
["OpenFOAM Decompose " dummy t]
["OpenFOAM Standard Randbedingungen Erstellen " opf_boundaries t]
Or use some other scripts like python:
import os
import sys
os.chdir(os.path.dirname(sys.argv[1]))
os.system("cp -a /home/gcae504/SCR1/Software/Vorlagen/OpenFOAM_Standard . ")
Obviously you need some more templates, if you are using a lot of different solvers.
Fabian
braennstroem is offline   Reply With Quote
Old   October 9, 2008, 02:35
Default If you want the same as Fabian
Mark Olesen
olesen has a spectacular aura aboutolesen has a spectacular aura about
If you want the same as Fabian, but without emacs, see if "foamCopySettings -help" does what you want.
olesen is offline   Reply With Quote
Old   October 9, 2008, 03:15
Default Hi, foamCopySettings does a
Håkan Nilsson
hani is on a distinguished road
foamCopySettings does a part of the job. Another part of the job is (when the mesh has been created) to modify the boundary conditions in the 0 directory according to a given 'boundary' file in constant/polyMesh. This was previously done by FoamX, and this was in my opinion the only thing that was useful with FoamX. Is there any script or application that does this in 1.5? I haven't found any yet.
Håkan.
hani is offline   Reply With Quote
Old   October 9, 2008, 03:43
Default I never tried FoamX to discove
Mark Olesen
I never tried FoamX to discover anything useful in it, but adjusting the boundary conditions to match the polyMesh/boundary was always *really* annoying.
With the new dictionary expansion mechanism, however, it becomes much easier. In this case I would prefer to stick to my favourite editor. Here's a small example example-0.tar.gz
Switching one of the inlets on and all the others off is just a matter of setting a link to the appropriate boundaryField-* file. These files are easily generated with a script.
Old   October 9, 2008, 04:33
Default Hi, This actually looks qui
Håkan Nilsson
This actually looks quite useful. Thanks!
Actually, FoamX used the physicalType in the boundary file to generate the time directories automatically. It used configuration files supplied in each solver/FoamX directory so that the boundary conditions were set according to that specific solver (Those FoamX directories are removed in 1.5.x). The solver was chosen in the controlDict. I found this quite useful, although I seldom used it. There is a need for a similar application that does the same thing, but without FoamX. I want to be clear that I do not want FoamX back!
I will try out your new approach.
Thanks!
Håkan.
Old   October 9, 2008, 06:04
Default Seconded! I hated FoamX, but a
Gavin Tabor
grtabor is on a distinguished road
Seconded! I hated FoamX, but a convenient automated case generation mechanism would be useful, even if the actual editing has to be done by hand.
Gavin
grtabor is offline   Reply With Quote
Old   October 9, 2008, 07:23
Default PyFoam is another approach. Di
Fabian Braennstroem
PyFoam is another approach. Different python scripts could do the job in the old fashion:
PipeWandrb.py
Though, one has to be consistent with the naming...
Fabian
Old   October 9, 2008, 07:49
Default Hi, for non huge cases I fi
  #11
Niklas Wikstrom
wikstrom is on a distinguished road
for non huge cases I find this utility helpful creating new fields:
createFieldTemplates.tgz
It simply creates a mesh, reads which fields to write from command line, creates them with a default BC and writes them to disk.
What about the "new dictionary expansion"? I fail to understand...
/Niklas
wikstrom is offline   Reply With Quote
Old   October 9, 2008, 07:59
Default Now with -compressible availab
  #12
Niklas Wikstrom
Now with -compressible available...
/Niklas
Old   October 9, 2008, 09:09
Default Splendid Niklas! A small tu
  #13
Håkan Nilsson
Splendid Niklas!
A small tutorial:
The syntax seems to be:
createFieldTemplates -scalarFields "(p k epsilon)" -vectorFields "(U)"
What is missing is some option to use physicalType from the boundary file, or to list all the possible boundary conditions for each patch and variable. I guess that there is some list of possible boundary conditions that can be reached, and printed out...
Example:
If a variable can use boundary conditions zeroGradient, and fixedValue only, then it would be nice if this code would automatically output something like:
boundaryField
examplePatch
type zeroGradient;
// type fixedValue;
// value 0;
Then it would be easy to un-comment the appropriate lines that are wanted instead of the default one.
Håkan.
Old   October 9, 2008, 09:57
Default Oh, sorry for not including an
  #14
Niklas Wikstrom
Oh, sorry for not including an example command line; thanks Håkan.
It would be nice to have such functionality, although perhaps not through "physicalType" since this key seems on it's way out? (and was a tad confusing anyway, imho.)
However, to create templates for all or some possible BC's increases the complexity of the '5 minute code' I uploaded quite much and I have not the time for that at the moment. When I have something, I'll share it.
/niklas
Old   October 9, 2008, 15:13
Default Hi! Sorry for advertising (
  #15
Assistant Moderator
Bernhard Gschaider
gschaider will become famous soon enoughgschaider will become famous soon enough
Hi!
Sorry for advertising (I won't quote the full help here):
pyFoamCreateBoundaryPatches.py [options] <fieldfile>
Takes a field-file. Looks up the polyMesh/boundary-file of the case and adds
the corresponding patches to the boundary field setting it to zeroGradient for
all patches and walls
The online-help doesn't say that of course patches like symmetryPlane are set to that type in the field file. Together with the --filter and the --default option a lot can be done if there is a consistent naming for the boundaries. Like
pyFoamCreateBoundaryPatches.py --filter="heated.+" --default="{'type':'fixedValue','value':'uniform 800'}" myCase/0/T
to set all patches that start with "heated" to a fixed temperature of 800
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
gschaider is offline   Reply With Quote
Old   October 10, 2008, 03:12
Default Bernhard, I think that you sho
  #16
Håkan Nilsson
Bernhard, I think that you should really advertise pyFoam more. I suggest that you propose a talk on pyFoam at the fourth workshop. Then there is also a need for a talk on the other developments you have made. It is an impressive amount of work!
I must admit - I did't have the time to use pyFoam yet, but I just opened your Wiki and started to have a look at it.
Håkan.
Old   October 10, 2008, 05:09
Default Hi Hakan! Thanks for your k
  #17
Assistant Moderator
Bernhard Gschaider
Hi Hakan!
Thanks for your kind words.
BTW: Fabian. I liked your script as an example for the usage of PyFoam. May I just add one remark. The Functionality of the pyFoam-Utilities is implemented as classes in the PyFoam.Applications-hierarchy that simply get a list with the command line arguments. This means that instead of the os.system("pyFoamCreateBoundary ....") you could use CreateBoundaryPatches(args=["--overwrite",case0k]). Also the os.system("cp ...")s might be replaced with a CloneCase-call
Bernhard
Old   October 10, 2008, 08:27
Default Hi Bernhard, I have been pl
  #18
Håkan Nilsson
Hi Bernhard,
I have been playing for a while :-)
I guess that you might have a hint on how to reduce the number of commands for the example I show below. In the example I want to run the icoFoam/elbow case with simpleFoam. Is there a way to reduce the number of PyFoam commands?
cp -r $FOAM_TUTORIALS/simpleFoam/pitzDaily $FOAM_RUN/simpleElbow
cp -r $FOAM_TUTORIALS/icoFoam/elbow/elbow.msh $FOAM_RUN/simpleElbow
cd $FOAM_RUN/simpleElbow
fluentMeshToFoam elbow.msh
pyFoamCreateBoundaryPatches.py --verbose --clear-unused 0/U
pyFoamCreateBoundaryPatches.py --verbose --overwrite --filter="wall.+" --default="{'type':'fixedValue','value':'uniform (0 0 0)'}" 0/U
pyFoamCreateBoundaryPatches.py --verbose --overwrite --filter="velocity-inlet-5" --default="{'type':'fixedValue','value':'uniform (1 0 0)'}" 0/U
pyFoamCreateBoundaryPatches.py --verbose --overwrite --filter="velocity-inlet-6" --default="{'type':'fixedValue','value':'uniform (0 3 0)'}" 0/U
pyFoamCreateBoundaryPatches.py --verbose --clear-unused 0/p
pyFoamCreateBoundaryPatches.py --verbose --overwrite --clear-unused --filter="pressure.+" --default="{'type':'fixedValue','value':'uniform 0'}" 0/p
pyFoamCreateBoundaryPatches.py --verbose --clear-unused 0/k
pyFoamCreateBoundaryPatches.py --verbose --overwrite --filter="velocity-inlet.+" --default="{'type':'turbulentIntensityKineticEnergyI nlet','intensity':'0.1', 'value':'uniform 0.375'}" 0/k
pyFoamCreateBoundaryPatches.py --verbose --clear-unused 0/epsilon
pyFoamCreateBoundaryPatches.py --verbose --overwrite --filter="velocity-inlet.+" --default="{'type':'turbulentMixingLengthDissipation RateInlet','mixingLength': '0.05', 'value':'uniform 14.855'}" 0/epsilon
pyFoamWriteDictionary.py system/controlDict endTime 300
rm 0/nuTilda
rm 0/R
simpleFoam
Håkan.
Siemen likes this.
Old   October 17, 2008, 07:04
Default Hi Hakan! I'm afraid it doe
  #19
Assistant Moderator
Bernhard Gschaider
Hi Hakan!
I'm afraid it doesn't work much simpler than that. The only thing I spotted is that for subsequent calls for a field the --clear-unused option can be omitted (but it doesn't hurt either)
Just as a preview: inspired by this thread I'm working on a util that generates a case using a description file. But I'll need two or three more train-rides to complete it ....
Bernhard
Old   October 21, 2008, 02:49
Default With all possible respect to
  #20
Niklas Wikstrom
With all possible respect to Python and pyFoam - I love python- I still want to expand the functionality of the createFieldTemplates app above.
I am trying to write a changeDictionaryDict from field and boundaryMesh information. However, I'm lost among dictionaries and entries. Anyone with an example code creating and writing a dictinoary? I allmost got there using IOdictionary, but IOdictionary::writeData does not produce andy line breaks.
The idea is that if all fields are created with default patches along with a corresponding changeDictionaryDict, it's only a matter of editing the dict and run changeDictionary. I'd like that.
/N
restart a case with .trn file in command line way? wayne CFX 0 October 10, 2008 09:02
Command line help Omer CFX 0 August 29, 2008 07:44
Cloning a case or creating a new case for 16 processes mellanoxuser OpenFOAM Running, Solving & CFD 0 February 8, 2008 16:52
Backup from the command line Rui CFX 6 February 22, 2005 10:19
Cloning a case from the command line Daniele Panara (Panara) OpenFOAM Pre-Processing 2 February 1, 2005 09:58
