October 21, 2008, 05:47 |
hi friend,
I am usi
hi friend,
I am using version1.5, my calculation always its saying maximum number of iteration reached after then its not calculating. so i want to increase the number of ITERATION how can i increase the iteration????? can you help me to do that. have a nice day siva |
October 21, 2008, 06:05 |
Hi Siva,
it seems that your
Tian
Hi Siva,
it seems that your boundary conditions are set up not correct. Bye Thomas
BIM HVACTool, The Green Building Simulation Tool for OpenFOAM, Energy Plus and Radiance. |
October 21, 2008, 06:50 |
hi Thomas,
I have a
hi Thomas,
I have attached my BC here please have a look and tell me what is wrong in that /*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.5 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ // FoamX Mesh Description File FoamFile { version 2.0; format ascii; class polyBoundaryMesh; object boundary; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // ( INLE1 { type patch; physicalType inlet; startFace 6030423; nFaces 1711; } INLE2 { type patch; physicalType inlet; startFace 6032134; nFaces 1496; } INLE3 { type patch; physicalType inlet; startFace 6033630; nFaces 1834; } INLE4 { type patch; physicalType inlet; startFace 6035464; nFaces 1731; } OUTL5 { type patch; physicalType outlet; startFace 6037195; nFaces 1214; } OUTL6 { type patch; physicalType outlet; startFace 6038409; nFaces 1214; } SYMP7 { type symmetryPlane; physicalType symmetryPlane; startFace 6039623; nFaces 3615; } SYMP8 { type symmetryPlane; physicalType symmetryPlane; startFace 6043238; nFaces 3868; } WALL9 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6047106; nFaces 1204; } WALL10 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6048310; nFaces 36525; } WALL11 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6084835; nFaces 13890; } WALL12 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6098725; nFaces 9335; } WALL13 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6108060; nFaces 47426; } WALL14 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6155486; nFaces 169; } WALL15 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6155655; nFaces 167; } WALL16 { type wall; physicalType fixedTemperatureWallFunctions; startFace 6155822; nFaces 1376; } defaultFaces { type wall; physicalType adiabaticWallFunctions; startFace 6157198; nFaces 151051; } ) // ************************************************** *********************** // bye siva |
October 21, 2008, 06:54 |
Hi Siva,
I also got this er
Tian
Hi Siva,
I also got this error sometimes. Than I had to change my pressure bc at time 0. Have a look in the time folder 0. Bye Thomas
October 21, 2008, 08:32 |
Hi Thomas,
here i h
Hi Thomas,
here i have give my P file, please have a look and tell me what i have to change. what u have changed? please dont mistake me. // Field Dictionary FoamFile { version 2.0; format ascii; class volScalarField; object p; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [1 -1 -2 0 0 0 0]; internalField uniform 100000; boundaryField { INLE1 { type zeroGradient; } INLE2 { type zeroGradient; } INLE3 { type zeroGradient; } INLE4 { type zeroGradient; } OUTL5 { type fixedValue; value uniform 100000; } OUTL6 { type fixedValue; value uniform 100000; } SYMP7 { type symmetryPlane; } SYMP8 { type symmetryPlane; } WALL9 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL10 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL11 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL12 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL13 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL14 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL15 { type fixedFluxBuoyantPressure; value uniform 100000; } WALL16 { type fixedFluxBuoyantPressure; value uniform 100000; } defaultFaces { type fixedFluxBuoyantPressure; value uniform 100000; } } // ************************************************** *********************** // bye siva |
October 21, 2008, 09:04 |
Hi Siva,
can you give me yo
Tian
Hi Siva,
can you give me your email adresse? Maybe I can have a look to your case? Thanks Bye Thomas
October 21, 2008, 09:32 |
Hi Thomas,
ya sure
October 21, 2008, 15:42 |
Hi Siva,
if you sure you no
Tian
Hi Siva,
if you sure you not make some misstake you can increase the iteration if I am not wrong with: relTol 0.05; minIter 1; maxIter 1000; Bye Thomas
Viscosity increase | miquelvinya | OpenFOAM Running, Solving & CFD | 0 | October 8, 2007 04:10 |
Speed increase with new amd cpu | zonexo | Main CFD Forum | 19 | April 14, 2006 12:32 |
Increase maxsc2 | Konstantinos | Siemens | 12 | March 8, 2006 08:06 |
Velocity increase | Christian Cordeiro | CFX | 3 | April 3, 2003 21:09 |
How to Increase Speed? | steve podleski | Main CFD Forum | 23 | January 11, 2000 15:41 |
