-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Incompatible fields for operation (http://www.cfd-online.com/Forums/openfoam-pre-processing/62029-incompatible-fields-operation.html)
su_junwei October 15, 2008 06:44
Hi Khaled From the mess
Hi Khaled
From the message above, we can infer that the type of alpha and U are incompatible. for instance, volScalarField + volVectorField
I also noticed that the code segment below
+ fvm::Sp(ix, alpha)
it is a impilit operation, if alpha and U are not the same object, adding them will also cause the problems.
Hope this helps
Junwei
booz October 15, 2008 08:34
Hi Junwei, thanks for the a
Hi Junwei,
thanks for the answer.
For alpha i add
volVectorField alpha
IOobject
"alpha",
runTime.timeName(),
mesh,
IOobject::MUST_READ,
IOobject::AUTO_WRITE
mesh
I thought for ix it is enough to be a volScalar or a Scalar.
Khaled
