Problem with simpleFoam
Old   September 4, 2008, 03:50
Default hi guys, i am getti
sivakumar selvaraju
sivakumar is on a distinguished road
Send a message via Skype™ to sivakumar
hi guys,
i am getting this problem often for simple Foam as well as turbFoam.
the message is
Time = 243
DILUPBiCG: Solving for Ux, Initial residual = 0.0921126, Final residual = 0.00118057, No Iterations 1
DILUPBiCG: Solving for Uy, Initial residual = 0.0227887, Final residual = 0.000450739, No Iterations 1
DILUPBiCG: Solving for Uz, Initial residual = 0.0322668, Final residual = 0.000457125, No Iterations 1
#0 Foam::error::printStack(Foam:stream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#1 Foam::sigFpe::sigFpeHandler(int) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#2 ?? in "/lib64/libc.so.6"
#3 Foam::DICPreconditioner::calcReciprocalD(Foam::Fie ld<double>&, Foam::lduMatrix const&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#4 Foam::DICPreconditioner::DICPreconditioner(Foam::l duMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#5 Foam::lduMatrix::preconditioner::addsymMatrixConst ructorToTable<foam::dicprecond itioner>::New(Foam::lduMatrix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#6 Foam::lduMatrix::preconditioner::New(Foam::lduMatr ix::solver const&, Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#7 Foam::PCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libOpenFOAM. so"
#8 Foam::fvMatrix<double>::solve(Foam::Istream&) in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/lib/linux64GccDPOpt/libfiniteVol ume.so"
#9 main in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /simpleFoam"
#10 __libc_start_main in "/lib64/libc.so.6"
#11 Foam::regIOobject::readIfModified() in "/home/junkers/selv_si/OpenFOAM1.5/OpenFOAM-1.5/applications/bin/linux64GccDPOpt /simpleFoam"
Fließkommafehler
junkers-selv_si:~/OpenFOAM1.5/selv_si-1.5/run/tutorials/simpleFoam/kabine_withp/ kabine_p_KEpsilon 22:45 >
control
application simpleFoam;
startFrom startTime;
startTime 0;
stopAt endTime;
endTime 1000;
deltaT 1;
writeControl timeStep;
writeInterval 50;
purgeWrite 0;
writeFormat ascii;
writePrecision 6;
writeCompression uncompressed;
timeFormat general;
timePrecision 6;
runTimeModifiable yes;
please help me to rectify this problem.
with regards,
sivakumar
sivakumar is offline   Reply With Quote
Old   September 4, 2008, 13:48
Default Simply, your simulation diverg
Francesco Del Citto
fra76 is on a distinguished road
Simply, your simulation diverges, I'm afraid...
fra76 is offline   Reply With Quote
Old   September 5, 2008, 03:06
Default hello, how can i solv
sivakumar selvaraju
hello,
how can i solve this problem?
with regards,
sivakumar
Old   September 5, 2008, 13:09
Default You should play with your nume
Francesco Del Citto
You should play with your numerical schemes and/or improve the quality of your mesh.
Try to post here the output of checkMesh and your fvSchemes and fvSolution files. Maybe someone can suggest you some improvement...
Old   September 6, 2008, 11:01
Default Try manipulating internal Fiel
Ameya Durve
ameya is on a distinguished road
Try manipulating internal Field values. My experience with OpenFOAM tells me that the codes are very sensitive to initial values.
ameya is offline   Reply With Quote
What is phi in simpleFoam ehsan_vaghefi OpenFOAM Running, Solving & CFD 7 September 29, 2013 11:00
SimpleFoam Convergence problem skabilan OpenFOAM Running, Solving & CFD 6 May 31, 2013 03:21
Convergence problem using simpleFoam steady state vvqf OpenFOAM Running, Solving & CFD 12 May 18, 2011 07:51
Help Troubleshooting simpleFoam problem on Harpoon made mesh lhcamilo OpenFOAM Bugs 1 February 18, 2009 07:11
Using simpleFoam with water nico765 OpenFOAM Running, Solving & CFD 7 October 23, 2007 05:39
