-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   How to copy the simpleFoam case to turboFoam (http://www.cfd-online.com/Forums/openfoam-pre-processing/62047-how-copy-simplefoam-case-turbofoam.html)
sivakumar August 19, 2008 09:17
hello, i am using OpenF
hello,
i am using OpenFoam1.5, right now i am using simple foam, i want to use the same geometry for TurboFoam
how can i copy the simpleFoam case to turobofoam?
regards
sivakumar
fra76 August 19, 2008 13:44
Simply, adapt the system/contr
Simply, adapt the system/controlDict, system/fvSchemes and system/fvSolution to match your transient simulation requirements (you can take them from the turbFoam tutorial case if you don't have any clue).
Then, in the same directory, run "turbFoam".
That's all!
sivakumar August 20, 2008 06:34
thank you man i got it now, it
thank you man i got it now, its working fine.
milos November 17, 2009 08:42
I am using OpenFOAM 1.6 and I cannot find turbFoam. Can you tell me what is the appropriate substitute for the turbFoam solver in OF 1.6?
Thanks!
santos November 17, 2009 10:47
pisoFoam.
Regards,
Jose Santos
milos November 18, 2009 03:49
Thanks a million!
Milos
