Hallo World.
I'm trying to
Hallo World.
I'm trying to place a spherical bubble into my mesh. I thought about doing this with setting the parameter gamma with setFields. But I just know the command boxToCell and a bubble isn't really like a box .. Any ideas? |
Beware: Advertising of own stu
Beware: Advertising of own stuff
Look on the message-board or the Wiki for a thing called funkySetFields. I think there is even an example how to set a sphere with it somewhere Bernhard |
Hi, Sebastian,
you can do t
Hi, Sebastian,
you can do that with such steps: 1) Create spherical surface (for example, with Netgen) 2) Export this surface to stl-formal 3) use option surface surfaceToCell (like in cellSetDict) 4) run foamToVTK . . -cellSet <your_cell_set_name> 5) preview <your_cell_set_name> in paraview 6) Enjoy! |
Which one may be the easier wa
Which one may be the easier way?
Hi Sebastian
As far as I u
Hi Sebastian
As far as I understand you are using interFoam and you want to initialize the gamma field with a spherical bubble. If that is the case then funkySetFields is the best choice as it allows you to do that in a very simple way. Let me know if you still trying to do that as I can send you the code (courtesy Bernhard) which compiles with the 1.4.1 version. http://www.cfd-online.com/OpenFOAM_D...ges/1/7511.jpg With Regards Jaswinder |
Sending me the code would be g
Sending me the code would be great.
Send it to NOSPAM.sebastian.gatzka@stud.tu-darmstadt.de (without the NOSPAM.) :-) Thanks a lot ... What is your setup in the picture used for? I would like to simulate a rising bubble to investigate it's terminal velocity. |
Hi Sebastian
This is just
Hi Sebastian
This is just a trial setup to see how one can initialize the bubble and use interFoam to simulate bubble rising. it lacks the proper physics setup It would be nice if you could share your experience one you have simulated the rising bubble up to its terminal velocity. I send you the code right now. Let me know if it won't compile or some other help required to initialize the bubble. With Regards Jaswi |
Hi!
The most recent version
Hi!
The most recent version of funkySetFields can be downloaded via the subversion command in the Downloads section of http://openfoamwiki.net/index.php/Co...funkySetFields Bernhard |
I have seen the file, but what
I have seen the file, but what is subversion?
I'm not yet familiar with the Linux environment.. |
Ok, after installing subversio
Ok, after installing subversion and flex (not knowing what these are exactly doing) I get this strange listing, wenn running wmake funkySetFields:
Making dependency list for source file ValueExpressionParser.yy could not open file ValueExpressionParser.tab.hh for source file ValueExpressionParser.yy Segmentation fault (core dumped) Making dependency list for source file ValueExpressionLexer.ll could not open file ValueExpressionParser.tab.hh for source file ValueExpressionLexer.ll Segmentation fault (core dumped) Making dependency list for source file ValueExpressionDriver.C could not open file ValueExpressionParser.tab.hh for source file ValueExpressionDriver.C Segmentation fault (core dumped) Making dependency list for source file funkySetFields.C could not open file ValueExpressionParser.tab.hh for source file funkySetFields.C Segmentation fault (core dumped) SOURCE=ValueExpressionParser.yy ; rm -f Make/linuxGccDPOpt/ValueExpressionParser.C Make/linuxGccDPOpt/ValueExpressionParser.tab.hh; bison -ra -v -d $SOURCE ; mv *.tab.cc Make/linuxGccDPOpt/ValueExpressionParser.C ; mv *.tab.hh Make/linuxGccDPOpt/ValueExpressionParser.tab.hh ; mv *.hh Make/linuxGccDPOpt ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/ValueExpressionParser.C -o Make/linuxGccDPOpt/ValueExpressionParser.o ValueExpressionParser.tab.cc: In member function 'unsigned char ve::ValueExpressionParser::yytranslate_(int)': ValueExpressionParser.tab.cc:1865: warning: use of old-style cast SOURCE=ValueExpressionLexer.ll ; rm Make/linuxGccDPOpt/ValueExpressionLexer.C ; flex -f $SOURCE ; mv *.c Make/linuxGccDPOpt/ValueExpressionLexer.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c Make/linuxGccDPOpt/ValueExpressionLexer.C -o Make/linuxGccDPOpt/ValueExpressionLexer.o rm: Entfernen von „Make/linuxGccDPOpt/ValueExpressionLexer.C" nicht möglich: No such file or directory lex.ve.c:340: warning: use of old-style cast lex.ve.c:410: warning: use of old-style cast lex.ve.c:410: warning: use of old-style cast lex.ve.c: In function 'int velex(ve::ValueExpressionParser::semantic_type*, ve::location*, ValueExpressionDriver&)': lex.ve.c:6854: warning: use of old-style cast lex.ve.c:6854: warning: use of old-style cast lex.ve.c:6871: warning: use of old-style cast lex.ve.c:6884: warning: use of old-style cast lex.ve.c:7224: warning: use of old-style cast lex.ve.c: In function 'int yy_get_next_buffer()': lex.ve.c:7403: warning: use of old-style cast lex.ve.c:7426: warning: use of old-style cast lex.ve.c:7439: warning: use of old-style cast lex.ve.c:7439: warning: use of old-style cast lex.ve.c:7460: warning: use of old-style cast lex.ve.c:7460: warning: use of old-style cast lex.ve.c: In function 'yy_state_type yy_get_previous_state()': lex.ve.c:7515: warning: use of old-style cast lex.ve.c:7515: warning: use of old-style cast lex.ve.c: In function 'int yyinput()': lex.ve.c:7633: warning: use of old-style cast lex.ve.c: In function 'yy_buffer_state* ve_create_buffer(FILE*, int)': lex.ve.c:7732: warning: use of old-style cast lex.ve.c:7741: warning: use of old-style cast lex.ve.c: In function 'void ve_delete_buffer(yy_buffer_state*)': lex.ve.c:7767: warning: use of old-style cast lex.ve.c:7770: warning: use of old-style cast lex.ve.c:7772: warning: use of old-style cast lex.ve.c: In function 'void veensure_buffer_stack()': lex.ve.c:7939: warning: use of old-style cast lex.ve.c:7957: warning: use of old-style cast lex.ve.c: In function 'yy_buffer_state* ve_scan_buffer(char*, yy_size_t)': lex.ve.c:7983: warning: use of old-style cast lex.ve.c: In function 'yy_buffer_state* ve_scan_bytes(const char*, int)': lex.ve.c:8036: warning: use of old-style cast lex.ve.c: In function 'void yy_push_state(int)': lex.ve.c:8072: warning: use of old-style cast lex.ve.c:8075: warning: use of old-style cast lex.ve.c:8075: warning: use of old-style cast lex.ve.c: In function 'int yy_init_globals()': lex.ve.c:8243: warning: use of old-style cast lex.ve.c:8256: warning: use of old-style cast lex.ve.c:8257: warning: use of old-style cast lex.ve.c: In function 'void* vealloc(yy_size_t)': lex.ve.c:8333: warning: use of old-style cast lex.ve.c: In function 'void* verealloc(void*, yy_size_t)': lex.ve.c:8345: warning: use of old-style cast lex.ve.c:8345: warning: use of old-style cast lex.ve.c: In function 'void vefree(void*)': lex.ve.c:8350: warning: use of old-style cast lex.ve.c: At global scope: lex.ve.c:8059: warning: 'void yy_push_state(int)' defined but not used lex.ve.c:8088: warning: 'void yy_pop_state()' defined but not used lex.ve.c:8100: warning: 'int yy_top_state()' defined but not used SOURCE=ValueExpressionDriver.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/ValueExpressionDriver.o SOURCE=funkySetFields.C ; g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread -c $SOURCE -o Make/linuxGccDPOpt/funkySetFields.o g++ -m32 -Dlinux -DDP -Wall -Wno-strict-aliasing -Wextra -Wno-unused-parameter -Wold-style-cast -O3 -DNoRepository -ftemplate-depth-40 -IMake/linuxGccDPOpt -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/meshTools/lnInclude -IlnInclude -I. -I/home/sega/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude -fPIC -pthread Make/linuxGccDPOpt/ValueExpressionParser.o Make/linuxGccDPOpt/ValueExpressionLexer.o Make/linuxGccDPOpt/ValueExpressionDriver.o Make/linuxGccDPOpt/funkySetFields.o -L/home/sega/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt \ -lfiniteVolume -lmeshTools -lOpenFOAM -ldl -lm -o /home/sega/OpenFOAM/sega-1.4.1/applications/bin/linuxGccDPOpt/funkySetFields Whats wrong with that? |
Nothing is wrong. It compiled
Nothing is wrong. It compiled fine. Those are just warnings NOT errors.
oops, what are those segfault
oops, what are those segfault messages doing up there? Did you follow the instructions correctly?
Try this:
Go into the folde
Try this:
Go into the folder that contains the file insertGenerated.sh. Then type: ./insertGenerated.sh Then type: cd .. Followed by: ./Allwmake That worked for me even though I am using Bison v 2.3. |
I don't know but it looks like
I don't know but it looks like the tool is working.
I could run funkyFieldSets and got the error message, that two arguments are needed. Doesn't that look like it's working? |
Try a simple test case and see
Try a simple test case and see. In any case I would not be too reassured with those segfault messages in there.
Hi everybody,
I had problems
Hi everybody,
I had problems in installing funkysetfield on my laptop. I made what Srinath Madhavan suggested on this forum. But I had this error message: from /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/finiteVolume/lnInclude/volFields.H:38, from ValueExpressionParser.yy:9, from ValueExpressionParser.C:38: /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:58: error: ISO C++ forbids declaration of 'ostream' with no type /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:58: error: expected ';' before '&' token /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:64: error: ISO C++ forbids declaration of 'ostream' with no type /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:64: error: expected ';' before '&' token /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:70: error: expected `;' before 'const' /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:70: error: ISO C++ forbids declaration of 'ostream' with no type /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:70: error: expected ';' before '&' token /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:76: error: expected `;' before 'public' /home/carlo/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/OSstream.H:83: error: expected `)' before '&' token ValueExpressionParser.yy:328: error: expected `}' at end of input ValueExpressionParser.yy:328: error: expected unqualified-id at end of input ValueExpressionParser.yy:328: error: expected `}' at end of input make: *** [Make/linuxGccDPOpt/ValueExpressionParser.o] Error 1 It is not everything because it's very long. I don't know what's the problem 'cause I made the same things on another computer and everything worked fine. Maybe someone could help me. Thank you. Carlo |
Hi Carlo!
You mean you're u
Hi Carlo!
You mean you're using the pre-generated files (./insertGenerated) and you'Re getting the sources from the SVN? Obviously I forgot to update the generated stuff after the last batch of changes. I updated this in the SVN Bernhard PS: I wasn't aware that people were still using these generated stuff |
Yes I used ./insertGenerated a
Yes I used ./insertGenerated and I got the file with svn (from the Wiki page.
carlo |
Hi, Carlo...
I have
Hi, Carlo...
I have a method. Of course, this may be tough or already been implemented in other executables. I have used this method in one my test cases. This works fine. Also i miss placed that test case, some where. Try this method and its cool. At the end you will feel like you have programmed something useful. I am sure that you have used the executable, "setShock" which is being employed in sonicFoam. Just extend it a little bit. Just get the value of the center of the sphere and radius as input. Then add the lines such that it satisfies the sphere equation when considered at that point, which is (x-a)^2 + (y-b)^2 + (z-c)^2 = r^2. Where a,b,c and r obviously the inputs given. Check the condition, if the cell center you are considering is greater than 'radius' given or not.... End of story. Just give it a try, instead of relying on some code, which you cant understand... http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
I was wondering if you
I was wondering if you could help, I'm a "newbie" to OpenFoam I have playing with it a little and would like to setup a case in which i have a circular volume of fluid and "drop" it (at the moment i am using interFoam). I managed use Setfields to create a "square" volume of fluid. How can I use Setfields to create a cylinder of fluid? or is there something else ? Hope to hear from you soon Ciao D |
