-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   FOAM FATAL IO ERROR size 1 is not equal to the given value of 26776 (http://www.cfd-online.com/Forums/openfoam-pre-processing/62055-foam-fatal-io-error-size-1-not-equal-given-value-26776-a.html)
hariya03 July 12, 2008 15:58
Hi everyone, I have workin
Hi everyone,
I have working with a simpleFoam case to see the flow of air from a inlet to outlet on a specified path.
The mesh has readed from a third party client and boundary patches are set in constant/polymesh.
The control dictionary were set to read for 300 as end time with a write interval of 100.
The fvsolution &t the intial boundary conditions
are feeded.
When I running the '0' time folder for simpleFoam
I got the following error
Application started with pid 22270
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4.1 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : simpleFoam /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam smartvalve12
Date : Jul 11 2008
Time : 16:48:44
Host : D6
PID : 22270
Root : /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
Case : smartvalve12
Nprocs : 1
Create time
Create mesh for time = 0
Reading field p
Reading field U
--> FOAM FATAL IO ERROR : size 1 is not equal to the given value of 26776
file: /home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam/smartvalve12/0/U from line 28 to line 229.
From function Field<type>::Field(const word& keyword, const dictionary& dict, const label s)
in file /home/dm2/henry/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM/lnInclude/Field.C at line 224.
FOAM exiting
Kindly advice me where i did wrong
If you need any further information, kindly ask me.
Thank you,
V.Hari
