MshToFoam
Old   July 7, 2008, 03:35
Default I have copied the .msh file co
Hari Krishnan
hariya03 is on a distinguished road
I have copied the .msh file converted from adventure on windows to the folder smartvalve in simplefoam
The smartvalve is a new case I created by right clicking on the case browser and by using create case command.
The mesh file is placed in the smartvalve case folder. I have not did any proceedings in system and constant directories. First I started the mshToFoam command directly.
The mshToFoam command exits as like this
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox
| \ / O peration | Version: 1.4.1
| \ / A nd | Web: http://www.openfoam.org
| \/ M anipulation |
Exec : mshToFoam OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
smartvalve CFD
Date : Jul 04 2008
Time : 18:21:20
Host : D6
PID : 22462
Root : OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam
Case : smartvalve
Nprocs : 1
Create time
--> FOAM FATAL IO ERROR : Attempt to get back from bad stream
file: CFD at line 1.
From function void Istream::getBack(token& t)
in file db/IOstreams/IOstreams/Istream.C at line 44.
FOAM exiting
could advice me where I had make mistake?
hariya03 is offline   Reply With Quote
Old   July 7, 2008, 04:20
Default Hi Hari! a) you are not ver
Assistant Moderator
Bernhard Gschaider
Hi Hari!
a) you are not very specific: what was the msh-file generated with? etc
b) from your introduction I assume that the msh-file worked on windows? Propably the file was touched on the windows-system and introduced LF/CR instead of only LF and now the converter is choking on the CR. See http://en.wikipedia.org/wiki/End_of_...ommon_problems and use dos2unix on the file
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   July 7, 2008, 06:04
Default Thank you Mr.Bernhard, Sorr
Hari Krishnan
Sorry for the inconvenience.
I have created a mesh file from the IGES of a part by using ADVENTURE ON WINDOWS. I have saved it in .msh extension.
I rebooted to LINUX(OpenSUSE 10.3) and placed in directory as below
home/harikr/OpenFOAM/harikr-1.4.1/run/tutorials/simpleFoam/smartvalve/cfd12.msh
smartvalve is the new case directory i created.
When using mshToFoam command i used this mesh file cfd12.msh and the above said error occurs.
I am new to linux environment.
also with reference to your website where to execute the "tr" command
Would I need to convert the .msh file suit to unix system? If means how to do it.
Could you advice me where to use this dos2unix command as whether in MS command prompt or in UNIX Xterminal itself.
Thankyou,
V.Hari Krishnan
Old   July 7, 2008, 10:23
Default Hi! dos2unix is installed o
Assistant Moderator
Bernhard Gschaider
Hi!
dos2unix is installed on most Linux-systems (usually from the package of the same name)
Usage is easy (as the man-page will tell you): dos2unix test.msh
Bernhard
Old   July 9, 2008, 03:22
Default Thank you Mr.Bernhard, The
Hari Krishnan
The problem is resolved. where the mistake is on myside. I have placed the mesh file in case directory instead of placing it in working directory
[mesh manipulation] MshToFoam hariya03 OpenFOAM Meshing & Mesh Conversion 3 July 9, 2008 10:41
MshToFoam hariya03 OpenFOAM Bugs 0 July 7, 2008 03:37
[Other] MshToFoam hariya03 OpenFOAM Meshing & Mesh Conversion 0 July 7, 2008 03:32
