Dear Friends,
This is hari, K
Dear Friends,
This is hari, Kindly help out me in this issue. I used OpenSuse 10.3 and OpenFoam 1.4.1. We installed the OpenSuse successfully and first of all we created this OpenFoam folder and installed the OpenFoam General.gtgz and LinuxGccDPopt.gtgz we used gcc-4.2.3.tar.gz, j2sdk 1.4.2_05.linux.tgz, Paraview-2.4.4.linux.tgz in a seperate linux folder. I have here posted the results of the Foam Installation Test and FoamX,FoamXHost Browser,./Allwmake commands. The Problem is I could not open the FoamX browser. Actually previously it opens, the very next day i could not open it. Kindly help me. 1.FOAM INSTALLATION TEST ------------------------ harikr@D6:~/OpenFOAM/OpenFOAM-1.4.1/bin> foamInstallationTest Executing /home/harikr/OpenFOAM/OpenFOAM-1.4.1/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: D6 OS: Linux version 2.6.22.5-31-default User: harikr User_config: /home/harikr/.bashrc Foam_config: /home/harikr/.OpenFOAM-1.4.1/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/harikr/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/harikr/OpenFOAM/harikr-1.4.1 yes no $FOAM_JOB_DIR /home/harikr/OpenFOAM/jobControl no yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/harikr/OpenFOAM/OpenFOAM-1.4.1 yes yes yes $FOAM_USER_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes no $FOAM_APPBIN ...1.4.1/applications/bin/linuxGccDPOpt yes yes yes $WM_DIR ...harikr/OpenFOAM/OpenFOAM-1.4.1/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH .../harikr/OpenFOAM/linux/j2sdk1.4.2_05 yes yes no $MICO_ARCH_PATH .../mico-2.3.12/platforms/linuxGccDPOpt yes yes yes $LAM_ARCH_PATH --------- env variable not set --------- yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...OAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt yes yes yes $FOAM_USER_LIBBIN ...nFOAM/harikr-1.4.1/lib/linuxGccDPOpt yes yes no $LAM_ARCH_PATH --------- env variable not set --------- yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc *** not installed *** CRITICAL ERROR java 1.4.2_05 /home/harikr/OpenFOAM/linux/j2sdk1.4.2_05/bin/java gzip 1.3.12 /usr/bin/gzip tar 1.3.12 /bin/tar icoFoam .../OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_D6 Successful yes Pinging_localHost Successful yes Test_rsh: No_telnet_running:_cannot_check* yes Test_ssh: No_telnet_running:_cannot_check* yes FATAL ERROR: No remote shell available. Foam1.4.1 enviroment requires either ssh and/or rsh. Contact your system administrator. ------------------------------------------------------------------------------- The system test has evoked 1 fatal error(s). The foam installation contains 1 critical error(s). Review the output for warning messages and consult the installation guide for trouble shooting. 2.FOAM X HOST BROWSER --------------------- harikr@D6:~/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt> FoamXHostBrowser /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : Apr 17 2008 Time : 16:10:35 Host : D6 PID : 19993 Root : Case : Nprocs : 1 Caught FoamXError exception in FoamXHostBrowser::main(int argc, char **argv) : FoamXError "Unexpected error" In function "FoamX::NameServer::connect(CORBA:http://www.cfd-online.com/OpenFOAM_D...part/proud.gifRB_ptr pOrb)" in file "NameServer.C" at line 220 Finishing FoamXHostBrowser::main(int argc, char **argv) 3.FOAMX ------- harikr@D6:~/OpenFOAM/OpenFOAM-1.4.1/bin> FoamX Starting NameServer with inet:D6:1234 ... Starting FoamX Host Browser with inet:D6:1234 ... /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4.1 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : FoamXHostBrowser Date : Apr 17 2008 Time : 16:18:06 Host : D6 PID : 20666 Root : Case : Nprocs : 1 HostBrowser running..... Setting LANG to en_EN Using jar /home/harikr/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX/ lib/FoamX.jar Using jar /home/harikr/OpenFOAM/OpenFOAM-1.4.1/applications/utilities/preProcessing/FoamX/ lib/jlfgr-1_0.jar java: xcb_xlib.c:52: xcb_xlib_unlock: Assertion `c->xlib.lock' failed. /home/harikr/OpenFOAM/OpenFOAM-1.4.1/bin/FoamX: line 244: 20670 Aborted $jdkhome/bin/java -cp "$jars" -DFoamX.SystemPath=$WM_PROJECT_DIR -DFoamX.SystemConfigPath=$FOAMX_CONFIG -DFoamX.UserConfigPath=$FOAMX_CONFIG FoamX.App $orbArgs $args /home/harikr/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 139: 20666 Killed FoamXHostBrowser -ORBNamingAddr $myIOP runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 20662). /home/harikr/OpenFOAM/OpenFOAM-1.4.1/bin/runFoamXHB: line 66: 20662 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref < /dev/null 4.ALLWMAKE ----------- harikr@D6:~/OpenFOAM/OpenFOAM-1.4.1> ./Allwmake + cd wmake + ./makeWmake ./makeWmake: line 34: make: command not found + cd src + ./Allwmake + cd /home/harikr/OpenFOAM/OpenFOAM-1.4.1/src/OpenFOAM + wmakeLnInclude . + wmake libso zlib-1.2.1 /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + '[' OPENMPI = OPENMPI -a '!' -r /home/harikr/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linuxGccDPOpt/l ib/libmpi.a -a '!' -r /home/harikr/OpenFOAM/OpenFOAM-1.4.1/src/openmpi-1.2.3/platforms/linuxGccDPOpt/l ib/libmpi.so ']' + '[' OPENMPI = LAM -a '!' -r /lib/libmpi.a -a '!' -r /lib/libmpi.so ']' + '[' OPENMPI = MPICH -a '!' -r /lib/libmpich.a -a '!' -r /lib/libmpich.so ']' + cd Pstream + ./Allwmake + wmake libso dummy /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + '[' OPENMPI = LAM -o OPENMPI = OPENMPI -o OPENMPI = MPI -o OPENMPI = MPICH -o OPENMPI = MPICH-GM -o OPENMPI = MPIGAMMA ']' + export WM_OPTIONS=linuxGccDPOptOPENMPI + WM_OPTIONS=linuxGccDPOptOPENMPI + wmake libso mpi /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOptOPENMPI/objectFiles was not created successfully + wmake libso OpenFOAM /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso lagrangian/basic /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso triSurface /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso edgeMesh /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso meshTools /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso finiteVolume /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd MGridGenGamgAgglomeration + ./Allwmake /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso sampling /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso dynamicMesh /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso dynamicFvMesh /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso topoChangerFvMesh /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso fvMotionSolver /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso engine /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso ODE /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso randomProcesses /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd thermophysicalModels + ./Allwmake + wmake libso specie /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso thermophysicalFunctions /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso liquids /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso liquidMixture /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso basic /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso combustion /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso laminarFlameSpeed /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso chemistryModel /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso pdfs /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd transportModels + ./Allwmake + wmake libso incompressible /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso interfaceProperties /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd turbulenceModels + ./Allwmake + wmake libso incompressible /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso compressible /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd LESmodels + ./Allwmake + wmake libso LESfilters /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmakeLnInclude incompressible + wmake libso LESdeltas /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso incompressible /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso compressible /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd lagrangian + ./Allwmake + wmake libso basic /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso dieselSpray /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso solidParticle /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso errorEstimation /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + wmake libso Gstream /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + cd malloc + ./Allwmake + wmake libo fbsdmalloc /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 198: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 199: make: command not found /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: cannot make, file Make/linuxGccDPOpt/objectFiles was not created successfully + '[' '!' -r /home/harikr/OpenFOAM/OpenFOAM-1.4.1/src/mico-2.3.12/platforms/linuxGccDPOpt/lib /libmico2.3.12.a ']' + cd applications + ./Allwmake + cd solvers + wmake all /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 166: make: command not found + cd utilities + wmake all /home/harikr/OpenFOAM/OpenFOAM-1.4.1/wmake/wmake: line 166: make: command not found + '[' 0 = 1 -a '' = doc ']' |
