July 29, 2011, 10:53 |
Set fields for an internal patch (surface)
Hisham Elsafti
Rep Power: 16 |
Hi Foamers
I need to define a parameter (e.g.some traction or temperature in a thermal-stress analysis) for a surface inside the geometry (not at boundary). My idea is that I can use setFields for the internal surface. One of the valid topoSetSource types that suggests such possibility is patchToFace. So is it possible to define an internal patch and refer to it in setFieldsDict? Else, how can I solve my problem? Thanks a lot. Best regards, Hisham |
July 30, 2011, 08:02 |
#2 | |||
Hisham Elsafti
Rep Power: 16 |
I have tried to modify the plateHole example of the solidDisplacementFoam solver. I have introduced internal patches via new (6) vertices, modified patches and edges, added (4) boundaries and a merge of two:
Links to images: https://picasaweb.google.com/1169016...96155045483218 https://picasaweb.google.com/1169016...96095904159202 https://picasaweb.google.com/1169016...96152225853202 |
internal patch, patchtoface, setfields |
Display Modes | |
[ICEM] Patch dependent surface mesh problem! | hadikhayyamian | ANSYS Meshing & Geometry | 14 | January 27, 2018 09:47 |
[Gmsh] Problem with Gmsh | nishant_hull | OpenFOAM Meshing & Mesh Conversion | 23 | August 5, 2015 03:09 |
mapFields : internal edges | Gearb0x | OpenFOAM Running, Solving & CFD | 3 | April 19, 2010 10:02 |
[Gmsh] Import problem | ARC | OpenFOAM Meshing & Mesh Conversion | 0 | February 27, 2010 11:56 |
CheckMeshbs errors | ivanyao | OpenFOAM Running, Solving & CFD | 2 | March 11, 2009 03:34 |
