FoamX refuses to open an interFoam tutorial case |
September 17, 2007, 10:47 |
Trying to follow a tutorial on
Damjan
Rep Power: 17 |
Trying to follow a tutorial on dam-break case I was unable to open this case within FoamX.
FoamX reported: "The Open Case operation failed due to getApplication::Invalid application class name interFoam". The terminal added: Caught FoamXError exception in FoamXCaseServer::main(int argc, char **argv) : FoamXError "getApplication::Invalid application class name 'interFoam'." In function "IPropertiesImpl" in file "IPropertiesImpl.C" at line 910 Finishing FoamXCaseServer::main(int argc, char **argv) Meanwhile, I can process the case from command line without problem using interFoam ... I went through icoFoam part of tutorial without problem and even processed some of my cases using icoFoam ind simpleFoam. Any hint would be appreciated. |
September 17, 2007, 13:46 |
InterFoam was never configured
Srinath Madhavan (a.k.a pUl|)
Rep Power: 21 |
InterFoam was never configured for FoamX. Check the response by Mattijs in the following post:
http://www.cfd-online.com/OpenFOAM_D...es/1/1698.html |
September 19, 2007, 12:23 |
There are config files for int
Jens Klostermann
Rep Power: 17 |
There are config files for interFoam and FoamX in the OF-1.4.1 dev (SVN) version. See the FoamX directory at http://openfoam-extend.svn.sourceforge.net/viewvc/openfoam-extend/trunk/Core/Ope nFOAM-1.4.1-dev/applications/solvers/multiphase/interFoam/
Just copy the FoamX directory in your OpenFOAM-1.4.1/applications/solvers/multiphase/interFoam/ directory. Hope it helps! Jens |
December 14, 2007, 01:51 |
I copy the FoamX directory as
Bowlderster
Rep Power: 17 |
I copy the FoamX directory as the above mentioned, but it still can not be opend by FoamX.
February 14, 2008, 05:06 |
Jens' solution unfortunately d
Jan Deeg
Jens' solution unfortunately didn't work for me, but the solution in this thread did:
http://www.cfd-online.com/OpenFOAM_D...tml?1197636423 |
March 12, 2008, 12:36 |
works like a charm...thanks Je
Daniel P. Combest
works like a charm...thanks Jens!
Help on interFoam writeControl in damBreak tutorial | asaha | OpenFOAM Running, Solving & CFD | 1 | February 2, 2009 07:36 |
FoamX cannot run tutorial damBreak | ahorvat | OpenFOAM Bugs | 5 | July 8, 2008 18:24 |
Problme to open FoamX | yoshikiy | OpenFOAM Installation | 21 | April 16, 2008 02:00 |
Cannot create cavityfoam in FoamX Tutorial 21 | airfoil | OpenFOAM Pre-Processing | 0 | January 19, 2008 10:55 |
problem in running FoamX in Open FOAM | Gaurav | Main CFD Forum | 3 | May 10, 2006 05:06 |
