FoamX MICO exception
Old   July 28, 2007, 16:55
Default I am trying to run FoamX and i
Chuck Ritter
critter is on a distinguished road
I am trying to run FoamX and it fails with the following error:
Starting NameServer with inet:headnode.hpc.here.edu:1234 ...
uncaught MICO exception: IDL:omg.org/CORBA/INITIALIZE:1.0 (0, not-completed)
/home/cfr100/OpenFOAM/OpenFOAM-1.4/bin/runFoamXHB: line 135: 13443 Aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
I have no cases or case files and it has worked before.
Someone else is already logged in and running FoamX, and their application is attached to port 1234. I think this is the problem.
Am I correct? Any ideas on the solution?
Thanks
chuck
critter is offline   Reply With Quote
Old   February 8, 2008, 04:23
Default I got the same problem with Ub
Florante
florante is on a distinguished road
I got the same problem with Ubuntu gutsy (andLinux).
any resolution?
Thank you.
florante is offline   Reply With Quote
Floating point exception? Ricky Wong FLUENT 19 March 28, 2020 15:32
Floating Point Exception?? Alex FLUENT 2 April 21, 2009 01:29
Porting FoamX to cygwin using the latest version of MICO 7islands OpenFOAM Pre-Processing 17 December 31, 2008 01:27
What is mico and why do I need it hemph OpenFOAM Installation 2 February 23, 2007 10:47
Floating point exception? Alex FLUENT 0 March 23, 2006 14:55
