Home > Forums > OpenFOAM Pre-Processing
Internalls walls
Old   November 20, 2007, 06:39
Default hi everybody i try to crea
rengu
hi everybody
i try to create internalls walls in OF thanks to this thread: http://openfoamwiki.net/index.php/Howto_importing_fluent_mesh_with_internal_wall s
i create my mesh with gambit but when i convert fluent mesh to openfoam it say me "Patch internal is internal to the mesh and is not being added to the boundary." but it don't create a set to use after splitmesh
what am i doing wrong?
what is the easy way to create a faceset ?
bestregards
Old   November 20, 2007, 08:06
Default With the new versions of fluen
Assistant Moderator
Bernhard Gschaider
With the new versions of fluentMeshToFoam (1.4+ I think) you have to explicitly trigger the writting of the sets with the -writeSets-option.
It has been asked before here. I will modify the Wiki-page accordingly
Bernhard
Note: I don't use "Friend"-feature on this forum out of principle. Ah. And by the way: I'm not on Facebook either. So don't be offended if I don't accept your invitation/friend request
Old   November 20, 2007, 08:24
Default thanks bernhard
rengu
thanks bernhard
Old   November 20, 2007, 08:47
Default sorry but i have got this erro
rengu
sorry but i have got this error
Create polyMesh for time = 0
#0 Foam::error::printStack(Foam:stream&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#1 Foam::sigSegv::sigSegvHandler(int) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#2 Uninterpreted: [0xffffe420]
#3 Foam::polyMesh::initMesh() in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#4 Foam::polyMesh::polyMesh(Foam::IOobject const&) in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/lib/linuxGccDPOpt/libOpenFOAM.so"
#5 main in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/splitMesh"
#6 __libc_start_main in "/lib/tls/i686/cmov/libc.so.6"
#7 Foam::regIOobject::write() const in "/home/gui/OpenFOAM/OpenFOAM-1.4.1/applications/bin/linuxGccDPOpt/splitMesh"
Erreur de segmentation (core dumped)
i suppose it's because startface like it say in the wiki
What mean "current number of faces" for the startface on the wiki?where i can found it?
best regards
Old   November 20, 2007, 08:59
Default Have a look at the faces-file
Assistant Moderator
Bernhard Gschaider
Have a look at the faces-file in polyMesh. At the start of the list it says how many faces are in the list. This is the "current number of faces". Use it for the startFace.
Old   November 20, 2007, 10:04
Default Alternatively, you can try to
Francesco Del Citto
fra76 is on a distinguished road
Alternatively, you can try to use fluent3DMeshToFoam shipped with OF 1.4.1.
If the internal walls are correctly set up in Fluent (i.e., with a Shadow face), it should be able to convert the mesh.
Francesco
fra76 is offline   Reply With Quote
Old   December 5, 2007, 09:35
Default Hi! I have a GAMBIT mesh wi
Mads Reck
gabriel_stokes is on a distinguished road
Hi!
I have a GAMBIT mesh with internal walls. I have exported it to a Fluent .msh file, which reads nicely into Fluent. I want it into OpenFOAM. It works beautifully if I do nothing, but naturally the internal walls are missing from the simulation. So,
I did the fluentMeshToFoam . <case> <meshfile.msh> -writeSets
fluentMeshToFoam recognises the internal walls but skips them, as noted by the original poster: "Patch internal is internal to the mesh and is not being added to the boundary."
I have multiple internal walls, defined as separate BC's in Gambit. I am trying to just get one of them active. So, in the boundary-file I add two entries:
InternalA
type wall;
nFaces A;
startFace B;
InternalB
type wall;
nFaces A;
startFace B;
I do not think that the question of what values to put A and B to, is clearly defined anywhere, or in the wiki. It is not clear to ignorant little me, at least.
I run the command splitMesh . <case> <gambit_bc_name> InternalA InternalB and it gives various error messages, depending on what values A and B have. Hence I have some questions, and please be accurate and comprehensible :-)
Question 1: I guess A and B has to be the same in InternalA and in InternalB, right?
Question 2: what should A be set to?
Question 3: what should B be set to?
I tried to set A to the first number which occurs in the sets/<gambit_bc_name> file. Makes no sense to me, as splitMesh should be able to read this number.
I tried to set B to the first number which occurs in the faces-file (just after the header). I believe this is the total face count. Makes no sense to me, why I should be using that number, as it should be available to splitMesh already from the faces-file.
Makes no sense, meaning that I do not understand at all what numbers should go in A and B.
Any help is greatly appreciated, thanks a bunch!
/Mads
I got a sets-directory in my polyMesh directory.
gabriel_stokes is offline   Reply With Quote
Old   December 5, 2007, 09:54
Default Hi Mads, Have you tried flu
caw
Christian Winkler
caw is on a distinguished road
Hi Mads,
Have you tried fluent3DMeshToFoam, this should do it.
Best regards
Christian
caw is offline   Reply With Quote
Old   December 6, 2007, 04:51
Default Hi Christian, fluent3dMeshT
Mads Reck
Hi Christian,
fluent3dMeshToFoam never worked for me. But, slightly embarrassed I admit, that fluentMeshToFoam now works, it seems. Well, actually it still breaks, but now it ends on "new cannot satisfy memory request". The mesh is probably too big. I have plenty of RAM so I wonder if changing to the 64bit version will alleviate this...?
Just, to clarify, since I may have caused some confusion, entries in the boundary file should read something like this:
InternalA
type wall;
nFaces 0;
startFace <facecount>;
InternalB
type wall;
nFaces 0;
where <facecount> is the total number of faces, found in the file ./<case>/constant/polyMesh/faces as the first entry after the header.
I have two follow-up questions, then.
Q1: will 64-bit version alleviate the memory limit-issue?
Q2: is fluent3DMeshToFoam the preferred choice?
Thanks!
/Mads
Old   December 6, 2007, 10:35
Default I had the same problem - I sho
Paul Mauk
plmauk is on a distinguished road
I had the same problem - I should import a fluent-mesh with an internal wall. This never worked with fluentMeshToFoam, but after reading these messages I've tried fluent3DMeshToFoam - and I have to confirm - it works perfectly!!
plmauk is offline   Reply With Quote
Old   December 10, 2007, 06:14
Default A quick hint on having multipl
  #11
Mads Reck
A quick hint on having multiple internal walls (i.e. defined in each own BC set)?
Do I run splitMesh multiple times or do I have to include all internals in one BC set in Gambit?
/Mads
Thread Tools
Trackbacks are On
Use wall function on some walls (not all walls) Mahdi10 FLUENT 1 February 16, 2009 12:52
HTC for low Y+ walls Tang FLUENT 0 March 15, 2007 16:55
how to cluster walls prc CD-adapco 2 December 26, 2006 04:56
too many walls?? matze CD-adapco 2 March 1, 2006 08:13
Thermal B.C at walls Riham FLUENT 3 January 27, 2004 14:57
