Home > Forums > OpenFOAM Pre-Processing
Looking for a tutorial to use CAD
Old   May 8, 2007, 05:18
Default hi all, I am new to openFo
pvc
hi all,
I am new to openFoam and I would like to run it with DNS into geometries previously designed in a CAD package. Actually, I have Solidworks so I can generate stl, step ...
I am a bit confused with the way to go because I had been told that OpenFoam would create a specific mesh to deal with DNS, So starting from a mesh looks weird, why not from a basic geometry?
AnyHow, is there a forum/topic/tutorial/webpage I have missed where I can see how to prompt blockmeshdict to consider my geometry and run a case?
Rgds
Pvc
Old   May 8, 2007, 17:51
Default I think like many finite volum
Billy
billy is on a distinguished road
I think like many finite volume solvers, OpenFOAM works better with a nice orthogonal hexahedral mesh. The problem is to generate that mesh with a free open source mesh generator. It's a pitty Cubit isn't open source it seems like a perfect mesh generator for OpenFOAM.
billy is offline   Reply With Quote
Old   May 9, 2007, 08:26
Default What about Netgen? It can prod
sradl's Avatar
Stefan Radl
sradl is on a distinguished road
What about Netgen? It can produce nice tetrahedal meshes.
Has anyone experience if its worth trying Cubit instead of Netgen to have hexahedral meshes?
Cheers
Stefan
sradl is offline   Reply With Quote
Old   May 9, 2007, 19:21
Default As far as i know you won't be
Peter Hering
peterh is on a distinguished road
As far as i know you won't be able to get your hands on a copy of Cubit unless you pay 300$... (if I'm wrong, please tell me where to get a free copy of the software if its possible)
What I think would be a nice way to produce hexahedral meshes for OF is some kind of graphical "blockMeshDict-generator". It wouldn't get that complicated to produce meshes with more than say 4-6 blocks or so in a simple textfile. Perhaps m4 is a good way to go, but it's still quite messy...
For the meshing, you could try harpoon, it can read .stl and produces hex-dominant meshes, and it has a native OpenFoam export function. You can get a trialversion for free. Since i got my key yesterday, i didn't have the time to play around with it..
Does anyone have some experience with harpoon?
Peter
peterh is offline   Reply With Quote
Old   May 9, 2007, 19:52
Default Hi, How much does harpoon c
Billy
How much does harpoon cost? I would also like to know which is the best mesh generator in the market or with the best quality/cost ratio.
Old   May 10, 2007, 11:50
Default Sandia does charge $300 for a
Karl Merkley
kgmerk is on a distinguished road
Sandia does charge $300 for a research license mostly to cover the administrative costs of handling their required licensing procedure. It'll cost _much_ more to get a commercial license of Cubit because there is a large cost associated with some commercial 3rd party libraries.
I'm looking at adding export capabilities to Cubit to support OpenFOAM. We've recently added a CGNS export. What would be the preferred export format from this group?
kgmerk is offline   Reply With Quote
Old   May 10, 2007, 14:31
Default Did anyone of you used SolidWo
paka is on a distinguished road
Did anyone of you used SolidWorks? VectorWorks?
Thanks,
K
paka is offline   Reply With Quote
Old   May 11, 2007, 03:39
Default Hi Peter, I read that you s
lam
Hoang-Lam
lam is on a distinguished road
Hi Peter,
I read that you said you received a key from Harpoon?
How did you do?
I filled something to request a key (otherwise, I saw that Harpoon does not work)on their site 4 days ago, but I have not received any thing.
How long had you waited for?
Lam
lam is offline   Reply With Quote
Old   May 11, 2007, 10:55
Default Hey Lam, they need some tim
Peter Hering
Hey Lam,
they need some time to process your request, in my case, I was waiting for about ten days .
Perhaps it took them so long because i got my key from the german retailer, and not directly from Sharc.
Peter
Old   May 15, 2007, 03:38
Default Hi Peter, So I have to wait
lam
Hoang-Lam
Hi Peter,
So I have to wait.
But if you try Harpoon, maybe you can tell use if Harpoon can make nice mesh for Foam.
See you,
Lam
Old   May 15, 2007, 08:47
Default Hey Karl, what about a free
  #11
sradl's Avatar
Stefan Radl
Hey Karl,
what about a free trial version of cubit? I'd like to test it for importing a *.stl file from SolidWorks.
Since OpenFOAM can convert several mesh formats (see http://www.opencfd.co.uk/openfoam/in...meshConversion)
and I'm currently working with NetGen, I'd prefer the "Netgen Natural format". It is basically a list of points and indices for connection.
cheers
Stefan
Old   July 28, 2007, 16:36
Default Hi Karl & Bill, we now have
  #12
sradl's Avatar
Stefan Radl
Hi Karl & Bill,
we now have an academic version of CUBIT and I tried to export an ideas mesh file. I used ideasUnvToFoam to import and it seems to work. However (beside some minor warnings), the program aborts with the error message "cell type 171 not supported" when it reads the cell information.
I also tried patran neutral and abaqus files without success.
Any help appreciated!
br
Stefan Radl
Old   October 11, 2007, 05:10
Default Hi all, i am a new user of
  #13
soufymer
soufy is on a distinguished road
Hi all,
i am a new user of openfoam. and i find a diffeculty to use it . please i need a help.
my question is: it is possible to import a geometrie in formet ".step " from a CAD ( for exemple solidworks ).
because for the complexe geometrie it's difficult.
please it's urgent!!!!!
soufy is offline   Reply With Quote
Old   October 11, 2007, 05:13
Default look into "salome" free softwa
  #14
sradl's Avatar
Stefan Radl
look into "salome" free software, it should work with your geometry file forma
Old   October 11, 2007, 05:25
Default Hi ok , i will try it. bu
  #15
soufymer
Hi
ok , i will try it.
but it not possible that i do my geometrie in solidworks and i import it in openfoam "in any format compatible " because i know how to use solidworks well. so salome it the first time that i know it.
tanks for help
Old   October 11, 2007, 05:41
Default hi, what is the version de sa
  #16
soufymer
hi,
what is the version de salome software that's works well with fedora
tanks
Old   October 11, 2007, 07:04
Default SALOME 3.2.6 works with Fedora
  #17
Ruben I. Mukhamadeev
benru is on a distinguished road
SALOME 3.2.6 works with Fedora, Debian & etc, but (as usual) you (perhaps) will need to do something "with arms" (install additional packages & etc). SALOME gives ability to create both tetrahedral and hexahedral meshes (and compound mesh too).
benru is offline   Reply With Quote
Thread Tools
Trackbacks are On
---------Tutorial help mech FLUENT 4 May 16, 2007 02:43
tutorial 6 in Fluent 6.2 tutorial and Mesh pilli4u FLUENT 2 April 2, 2007 05:09
3D Tutorial MJ FLUENT 0 January 16, 2007 09:45
tutorial masood yooceframandi FLUENT 1 January 25, 2005 13:28
tutorial adil FLUENT 0 March 8, 2004 04:48
