-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   FoamX CORBACOMM Failure (http://www.cfd-online.com/Forums/openfoam-pre-processing/62121-foamx-corbacomm-failure.html)
lcutrone August 5, 2007 11:44
Dear all, i tried to open wit
Dear all,
i tried to open with FoamX the remote test case repository located at yyyy.selfip.com from the local host xxxx.selfip.com: the two computer are connected by Internet.
I received the CORBA.COMM Failure message #201.
Do you have some ideas how to solve the problem??'
I attach the log of the error.
Regards,
Luigi
Doing (with timeout 0) : "ssh yyyy.selfip.com -l luigi FoamXCaseBrowser -ORBNamingAddr inet:xxxx.selfip.com:1234 &"
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.4 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXCaseBrowser
Date : Aug 05 2007
Time : 17:36:15
Host : yyyy.selfip.com
PID : 19271
Root :
Case :
Nprocs : 1
CaseBrowser running.....
org.omg.CORBA.COMM_FAILURE: vmcid: SUN minor code: 201 completed: No
at com.sun.corba.se.internal.iiop.ConnectionTable.get Connection(ConnectionTable.jav a:148)
at com.sun.corba.se.internal.iiop.ConnectionTable.get Connection(ConnectionTable.jav a:65)
at com.sun.corba.se.internal.iiop.GIOPImpl.getConnect ion(GIOPImpl.java:67)
at com.sun.corba.se.internal.corba.ClientDelegate.cre ateRequest(ClientDelegate.java :652)
at com.sun.corba.se.internal.corba.ClientDelegate.cre ateRequest(ClientDelegate.java :594)
at com.sun.corba.se.internal.corba.ClientDelegate.req uest(ClientDelegate.java:886)
at org.omg.CORBA.portable.ObjectImpl._request(ObjectI mpl.java:431)
at FoamXServer.CaseBrowser._ICaseBrowserStub.foamProp erties(_ICaseBrowserStub.java: 22)
at FoamX.CaseManagement.CaseBrowserModel.addCaseBrows erNodes(CaseBrowserModel.java: 613)
at FoamX.CaseManagement.CaseBrowserModel.startCaseBro wser(CaseBrowserModel.java:465 )
at FoamX.CaseManagement.CaseBrowserPanel$StartCaseBro wserAction.actionPerformed(Cas eBrowserPanel.java:1607)
at FoamX.CaseManagement.CaseBrowserPanel.handleMouseO pen(CaseBrowserPanel.java:1383 )
at FoamX.CaseManagement.CaseBrowserPanel.OnMouseClick ed(CaseBrowserPanel.java:1246)
at FoamX.CaseManagement.CaseBrowserPanel.access$200(C aseBrowserPanel.java:69)
at FoamX.CaseManagement.CaseBrowserPanel$2.mouseClick ed(CaseBrowserPanel.java:1149)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEvent Multicaster.java:211)
at java.awt.Component.processMouseEvent(Component.jav a:5103)
at java.awt.Component.processEvent(Component.java:489 7)
at java.awt.Container.processEvent(Container.java:156 9)
at java.awt.Component.dispatchEventImpl(Component.jav a:3615)
at java.awt.Container.dispatchEventImpl(Container.jav a:1627)
at java.awt.Component.dispatchEvent(Component.java:34 77)
at java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:3483)
at java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:3207)
at java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:3128)
at java.awt.Container.dispatchEventImpl(Container.jav a:1613)
at java.awt.Window.dispatchEventImpl(Window.java:1606 )
at java.awt.EventQueue.dispatchEvent(EventQueue.java: 480)
at java.awt.EventDispatchThread.pumpOneEventForHierar chy(EventDispatchThread.java:2 01)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:151 )
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:145)
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:137)
at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:100)
