Dear all,
I am trying to s
Dear all,
I am trying to specify nonuniform boundary conditions at "inlet". For some reason, I am keep geting this error message when I try to access the 0/U file. Can anyone give me some help and advise? Thank you very much. --> FOAM FATAL IO ERROR : attempt to read beyond EOF file: /home/qtian/OpenFOAM/qtian-1.4/run/tutorials/simpleFoam//bump1/0/U::value at line 58. From function ITstream::read(token& t) in file db/IOstreams/Tstreams/ITread.C at line 70. FOAM exiting U file look like this, internalField uniform (0 0 0); boundaryField { Bottom { type fixedValue; value uniform (0 0 0); } leftwall { type slip; } outlet { type zeroGradient; } rightwall { type slip; } inlet { type fixedValue; value nonuniform; Line 58 } top { type slip; } } |
if you want to specify
if you want to specify a non uniform boundary condition, you should specify the field values inside the 0/U file. In my case, I dealt with non uniform velocity fields (vector field) and temperature fields (scalar field) at a boundary called "goutte" (droplet in english) Here are my 0/U and 0/T files as example. Good luck. Bruno /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class volVectorField; object U; } // ************************************************** *********************** // dimensions [ 0 1 -1 0 0 0 0 ]; internalField uniform ( 15. 0. 0. ); boundaryField { inlet { type fixedValue; value uniform ( 15. 0. 0. ); } inlet1 { type fixedValue; value uniform ( 15. 0. 0. ); } goutte { type fixedValue; value nonuniform List<vector> 32 ( ( 0.125901997 0.138911426 0. ) ( 0.128139153 0.172775626 0. ) ( 0.126960248 0.211820379 0. ) ( 0.120514534 0.254806578 0. ) ( 0.107431941 0.30025211 0. ) ( 0.0867254138 0.346227229 0. ) ( 0.0579536967 0.390691847 0. ) ( 0.0212141946 0.431824267 0. ) ( 0.138057172 0.00678228773 0. ) ( 0.135565937 0.0201092884 0. ) ( 0.131116718 0.0328430161 0. ) ( 0.126068711 0.0451080948 0. ) ( 0.121914245 0.0576611347 0. ) ( 0.11977531 0.0717905611 0. ) ( 0.120108962 0.0890788361 0. ) ( 0.122550257 0.111073039 0. ) ( -0.461236358 0.508895934 0. ) ( -0.393406957 0.530447841 0. ) ( -0.32478264 0.541867137 0. ) ( -0.257232815 0.543873072 0. ) ( -0.192155391 0.537038386 0. ) ( -0.130680457 0.521705806 0. ) ( -0.0739541948 0.498558581 0. ) ( -0.0230022091 0.468220979 0. ) ( -0.802104294 0.0394048579 0. ) ( -0.788241446 0.116924562 0. ) ( -0.764009297 0.191374391 0. ) ( -0.73147279 0.261725157 0. ) ( -0.690910041 0.326776087 0. ) ( -0.642638564 0.385182768 0. ) ( -0.587392509 0.435639977 0. ) ( -0.526437223 0.477134943 0. ) ); } outlet { type zeroGradient; } def1 { type wedge; } def2 { type wedge; } } // ********************************************** // /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.4 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; root ""; case ""; instance ""; local ""; class volScalarField; object T; } // ************************************************** *********************** // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 873.; boundaryField { inlet { type fixedValue; value uniform 873.; } inlet1 { type fixedValue; value uniform 873.; } goutte { type fixedValue; value nonuniform List<scalar> 32 ( 316.607025 317.104828 317.483337 317.741577 317.88974 317.944489 317.9245 317.849274 312.305328 312.442383 312.751709 313.243347 313.877991 314.591553 315.318268 316.003143 316.917969 316.997284 317.094482 317.207031 317.332245 317.467346 317.606018 317.737732 316.933899 316.903168 316.853973 316.808655 316.785156 316.787842 316.81308 316.856873 ); } outlet { type zeroGradient; } def1 { type wedge; } def2 { type wedge; } } // ********************************************** // |
Frackowiak,
Thanks for your
Frackowiak,
Thanks for your help. It works right now. QT |
Expression for non uniform value?
Hi All,
I am looking for a method to update my partialSlip boundary condition from a uniform slip fraction to an expression (Maxwellian slip) in rhoSimpleFoam for OF 2.2.0. So currently I have in my U file: wall { type partialSlip; valueFraction uniform 0.01; } and want something like this wall { type partialSlip; valueFraction DynViscousity/Density*pow(PI/2*Density/Pressure,1/2); } Can I implement this within the U file? I am looking for a solution that does not involve compiling a new BC. Thanks in advance! |
Hi Bruno,
I am a new foamer. Can I ask how do you extract the vector list of your boundary "goutte" from face label? Thank you very much! |
