Problems when starting FoamX OpenFOAM14 Suse102 |
July 5, 2007, 14:47 |
Hello Group!
I am stuck wit
Stefan Weiland
Hello Group!
I am stuck with a problem with the FoamX case manager. Trying to start it by the command 'FoamX', I get the following two lines in response: Starting NameServer with inet:linux-o4vi:1234 ... nsd: error while loading shared libraries: libssl.so.0.9.7: cannot open shared object file: No such file or directory Afterwards nothing more happens and I have to use the ctrl-C combination to get back to a shell-prompt. I tried the networking-capabilities according to the README file in the OpenFoam-1.4 directory and I could not find any hint to the problem. My installation of OpenFOAM-1.4 on a SUSE10.2 distribution ran without any problems and the foamInstallationTest-script also tells me that the crucial systems should work (see dump of the foamInstallationTest below). I would really appreciate If someone could tell me what's wrong. At the moment I have not the faintest idea where to search... Thank's a lot for your help. Stefan Executing /home/stefan/OpenFOAM/OpenFOAM-1.4/bin/foamInstallationTest: Checking basic setup... ------------------------------------------------------------------------------- Shell: bash Host: linux-o4vi OS: Linux version 2.6.18.2-34-default User: stefan User_config: /home/stefan/.bashrc Foam_config: /home/stefan/.OpenFOAM-1.4/bashrc sourced correctly. ------------------------------------------------------------------------------- Checking main FOAM env variables... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Crit ------------------------------------------------------------------------------- $WM_PROJECT_INST_DIR /home/stefan/OpenFOAM yes yes $WM_PROJECT_USER_DIR /home/stefan/OpenFOAM/stefan-1.4 yes no $FOAM_JOB_DIR /home/stefan/OpenFOAM/jobControl yes yes ------------------------------------------------------------------------------- Checking the FOAM env variables set on the PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $WM_PROJECT_DIR /home/stefan/OpenFOAM/OpenFOAM-1.4 yes yes yes $FOAM_USER_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes no $FOAM_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes yes $WM_DIR /home/stefan/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes $FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes $CEI_HOME /usr/local/ensight/CEI no no $JAVA_PATH /usr yes yes no $MICO_ARCH_PATH ...mico-2.3.12/platforms/linuxGcc4DPOpt yes yes yes $LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes $MPICH_ARCH_PATH --------- env variable not set --------- no ------------------------------------------------------------------------------- Checking the FOAM env variables set on the LD_LIBRARY_PATH... ------------------------------------------------------------------------------- Environment_variable Set_to_file_or_directory Valid Path Crit ------------------------------------------------------------------------------- $FOAM_LIBBIN ...FOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt yes yes yes $FOAM_USER_LIBBIN ...enFOAM/stefan-1.4/lib/linuxGcc4DPOpt yes yes no $LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes ------------------------------------------------------------------------------- Software versions ------------------------------------------------------------------------------- Software Version Location ------------------------------------------------------------------------------- gcc ...figure /usr/bin/gcc java 1.5.0_08 /usr/bin/java gzip 1.3.5 /usr/bin/gzip tar 1.3.5 /bin/tar icoFoam ...M/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/icoFoam ------------------------------------------------------------------------------- Checking file/directory permissions... ------------------------------------------------------------------------------- File/directory Set Reqd Crit ------------------------------------------------------------------------------- Checking networking... ------------------------------------------------------------------------------- Action Result Crit ------------------------------------------------------------------------------- Pinging_linux-o4vi Successful yes Pinging_localHost Successful yes Test_rsh: Unsuccessful_connection_refused* yes Test_ssh: Successful yes (*) Only one of rsh or ssh is required by the Foam enviroment. ------------------------------------------------------------------------------- Base configuration ok. Critical systems ok. |
July 5, 2007, 15:05 |
Do a search for e.g. libssl.
Mattijs Janssens
Rep Power: 26 |
July 5, 2007, 15:08 |
OpenSUSE should have libssl in
Alberto Passalacqua
Rep Power: 36 |
OpenSUSE should have libssl installed by default. However, just open Yast -> Software -> Software management.
Search for "libssl.so.0.9.7" using the "Provides" option and install the corresponding package. It should be something like compat-openssl097g. Regards, Alberto
Alberto Passalacqua GeekoCFD - A free distribution based on openSUSE 64 bit with CFD tools, including OpenFOAM. Available as in both physical and virtual formats (current status: http://albertopassalacqua.com/?p=1541) OpenQBMM - An open-source implementation of quadrature-based moment methods. To obtain more accurate answers, please specify the version of OpenFOAM you are using. |
Starting FoamX error | jaswi | OpenFOAM Installation | 15 | February 7, 2012 14:53 |
Problem with starting FoamX | laker | OpenFOAM Installation | 2 | May 13, 2008 09:34 |
Problem Starting FoamX | kumar2 | OpenFOAM Installation | 1 | January 9, 2008 09:14 |
Starting FoamX on SUSE 102 | nick23369 | OpenFOAM Pre-Processing | 0 | May 18, 2007 05:56 |
Problem Starting FoamX | kumar2 | OpenFOAM Installation | 1 | February 2, 2006 14:08 |
