Problems when starting FoamX OpenFOAM14 Suse102
Old   July 5, 2007, 14:47
Default Hello Group! I am stuck wit
Stefan Weiland
weiste01 is on a distinguished road
Hello Group!
I am stuck with a problem with the FoamX case manager. Trying to start it by the command 'FoamX', I get the following two lines in response:
Starting NameServer with inet:linux-o4vi:1234 ...
nsd: error while loading shared libraries: libssl.so.0.9.7: cannot open shared object file: No such file or directory
Afterwards nothing more happens and I have to use the ctrl-C combination to get back to a shell-prompt.
I tried the networking-capabilities according to the README file in the OpenFoam-1.4 directory and I could not find
any hint to the problem.
My installation of OpenFOAM-1.4 on a SUSE10.2 distribution ran without any problems and the foamInstallationTest-script also tells me that the crucial systems should work (see dump of the foamInstallationTest below).
I would really appreciate If someone could tell me what's wrong. At the moment I have not the faintest idea where to search...
Thank's a lot for your help.
Stefan
Executing /home/stefan/OpenFOAM/OpenFOAM-1.4/bin/foamInstallationTest:
Checking basic setup...
Shell: bash
Host: linux-o4vi
OS: Linux version 2.6.18.2-34-default
User: stefan
User_config: /home/stefan/.bashrc
Foam_config: /home/stefan/.OpenFOAM-1.4/bashrc sourced correctly.
Checking main FOAM env variables...
Environment_variable Set_to_file_or_directory Valid Crit
$WM_PROJECT_INST_DIR /home/stefan/OpenFOAM yes yes
$WM_PROJECT_USER_DIR /home/stefan/OpenFOAM/stefan-1.4 yes no
$FOAM_JOB_DIR /home/stefan/OpenFOAM/jobControl yes yes
Checking the FOAM env variables set on the PATH...
Environment_variable Set_to_file_or_directory Valid Path Crit
$WM_PROJECT_DIR /home/stefan/OpenFOAM/OpenFOAM-1.4 yes yes yes
$FOAM_USER_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes no
$FOAM_APPBIN ...-1.4/applications/bin/linuxGcc4DPOpt yes yes yes
$WM_DIR /home/stefan/OpenFOAM/OpenFOAM-1.4/wmake yes yes yes
$FOAMX_PATH ...ations/utilities/preProcessing/FoamX yes no yes
$CEI_HOME /usr/local/ensight/CEI no no
$JAVA_PATH /usr yes yes no
$MICO_ARCH_PATH ...mico-2.3.12/platforms/linuxGcc4DPOpt yes yes yes
$LAM_ARCH_PATH ...c/lam-7.1.2/platforms/linuxGcc4DPOpt yes yes yes
$MPICH_ARCH_PATH --------- env variable not set --------- no
Checking the FOAM env variables set on the LD_LIBRARY_PATH...
$FOAM_LIBBIN ...FOAM/OpenFOAM-1.4/lib/linuxGcc4DPOpt yes yes yes
$FOAM_USER_LIBBIN ...enFOAM/stefan-1.4/lib/linuxGcc4DPOpt yes yes no
Software versions
Software Version Location
gcc ...figure /usr/bin/gcc
java 1.5.0_08 /usr/bin/java
gzip 1.3.5 /usr/bin/gzip
tar 1.3.5 /bin/tar
icoFoam ...M/OpenFOAM-1.4/applications/bin/linuxGcc4DPOpt/icoFoam
Checking file/directory permissions...
File/directory Set Reqd Crit
Checking networking...
Action Result Crit
Pinging_linux-o4vi Successful yes
Pinging_localHost Successful yes
Test_rsh: Unsuccessful_connection_refused* yes
Test_ssh: Successful yes
(*) Only one of rsh or ssh is required by the Foam enviroment.
Base configuration ok.
Critical systems ok.
weiste01 is offline   Reply With Quote
Old   July 5, 2007, 15:05
Default Do a search for e.g. libssl.
Mattijs Janssens
mattijs is on a distinguished road
http://www.cfd-online.com/cgi-bin/Op...3984#POST13984
mattijs is offline   Reply With Quote
Old   July 5, 2007, 15:08
Default OpenSUSE should have libssl in
Alberto Passalacqua
OpenSUSE should have libssl installed by default. However, just open Yast -> Software -> Software management.
Search for "libssl.so.0.9.7" using the "Provides" option and install the corresponding package. It should be something like compat-openssl097g.
Regards,
Alberto
Alberto Passalacqua
Starting FoamX error jaswi OpenFOAM Installation 15 February 7, 2012 14:53
Problem with starting FoamX laker OpenFOAM Installation 2 May 13, 2008 09:34
Problem Starting FoamX kumar2 OpenFOAM Installation 1 January 9, 2008 09:14
Starting FoamX on SUSE 102 nick23369 OpenFOAM Pre-Processing 0 May 18, 2007 05:56
Problem Starting FoamX kumar2 OpenFOAM Installation 1 February 2, 2006 14:08
