March 6, 2007, 16:52 |
I have installed OpenFOAM 1.3
Ery Djunaedy
Rep Power: 17 |
I have installed OpenFOAM 1.3 on an AMD64 ubuntu system today.
The installation is ok, I can run the first tutorial without problem. But when I try to start FoamX I receive this error: ****START ERROR********* Exec : FoamXHostBrowser Date : Mar 06 2007 Time : 14:53:42 Host : erydj-desktop PID : 11322 Root : Case : Nprocs : 1 HostBrowser running..... Using jar /home/erydj/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/lib /FoamX.jar Using jar /home/erydj/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/lib /jlfgr-1_0.jar /home/erydj/OpenFOAM/OpenFOAM-1.3/bin/FoamX: 243: /home/erydj/OpenFOAM/linuxAMD64/j2sdk1.4.2_05/bin/java: not found Killed runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 11318). ****END ERROR*********** It seems that the java executable cannot be found. I have checked that the file does exist in the specified directory. I found similar problem on OpenFOAM 1.2: http://www.cfd-online.com/OpenFOAM_D...tml?1151539351 The problem on that thread was missing app.class from lib/FoamX.jar. However, I could not even execute "jar lib/FoamX.jar" because it will have the same error message that "jar" file cannot be found. Furthermore, I believe that the missing app.class has been corrected in 1.3. Any suggestion where should I move from this point? Thanks, Ery |
May 3, 2007, 18:12 |
having the same problem with 1
Rep Power: 17 |
having the same problem with 1.4 on kubuntu feisty faun (fresh install with no previous OF versions).
there is a App.class in: OpenFOAM-1.4/applications/utilities/preProcessing/FoamX/lib/FoamX.jar Can the case difference cause the error? |
May 4, 2007, 08:53 |
I had a similar problem with F
Dominique Turmel
Rep Power: 17 |
I had a similar problem with FoamX on Fedora Core 6. I had to set SELinux secutiry to disabled... In a first time, it was set to "Strict" and that was the problem... Hope this can help!
Starting FoamX error | jaswi | OpenFOAM Installation | 15 | February 7, 2012 14:53 |
FoamX and Java Issues | olih | OpenFOAM Installation | 5 | March 30, 2008 17:22 |
FoamX starting on Fedora 8 x86_64 and i386 Error nsd ORBIIOPAddr %24myIOP ior %24FOAMX_CONFIGnsref %2360 devnull | rationaalinen | OpenFOAM Pre-Processing | 6 | December 2, 2007 11:40 |
FoamX not starting Javarelated error | agrahn | OpenFOAM Pre-Processing | 5 | October 20, 2007 05:33 |
Java error while starting FoamX | cfdengineering | OpenFOAM Pre-Processing | 16 | June 28, 2006 20:02 |
