April 3, 2007, 12:31 |
Hi
I am trying to test SIMP
Hoang-Lam
Rep Power: 17 |
Hi
I am trying to test SIMPLEFOAM with a Bird-Carreau law and I have a very trivial question: I noticed that, when running the non linear computation, I have to specify the number of iterations a priori, (their number is being suggested by the proogramme itself). Is it possible to run the programme in such a way that the computation interrupts automatically as soon as convergence is reached ? (comvergence criterium). Thank you in davance, Lam |
April 4, 2007, 05:07 |
Oh, THANKS a lot Mark, for rep
Hoang-Lam
Rep Power: 17 |
Oh, THANKS a lot Mark, for replying me!
I am going give a go right now! Cheers, Lam |
April 5, 2007, 04:40 |
I guess I wasn't explicit enou
Mark Olesen
Rep Power: 40 |
I guess I wasn't explicit enough. You can either solve the equation and ignore the return value:
solve(UEqn() == -fvc::grad(p)); OR solve the equation and use the return value: eqnResidual = solve(UEqn() == -fvc::grad(p)).initialResidual(); but not both. It is also essential to capture the mass residual. ie. replace pEqn.solve(); with if (nonOrth == 0) { eqnResidual = pEqn().solve().initialResidual(); maxResidual = max(eqnResidual, maxResidual); } else { pEqn().solve(); } The residuals from the turbulence equation are not directly accessible, but this might change in OpenFOAM 1.4 |
April 5, 2007, 06:46 |
It looks mostly reasonable exc
Mark Olesen
Rep Power: 40 |
It looks mostly reasonable except you don't need this line twice.
eqnResidual = solve(UEqn() == -fvc::grad(p)).initialResidual(); |
April 5, 2007, 09:20 |
Hi again Mark,
I had remove
Hoang-Lam
Rep Power: 17 |
Hi again Mark,
I had removed the line which is not needed as you said. And of course, I did the Allmake to update the simpleFoam.C file. I made a computation, but the result has not changed. You can take a look at my fvSolution file: *********************** solvers { p ICCG 1e-03 0.01; U BICCG 1e-03 0.1; k BICCG 1e-03 0.1; epsilon BICCG 1e-03 0.1; R BICCG 1e-03 0.1; nuTilda BICCG 1e-03 0.1; } *********************** I just want a 1e-03 solver tolerance. But the computation still stopps at the endtime (=4000 itrations). I just have a solution wich seems to not menage to reach the convergence. Can you give some advice to get it right? Thanks in advance, Lam |
April 5, 2007, 09:50 |
I don't wish to be impolite, b
Mark Olesen
Rep Power: 40 |
I don't wish to be impolite, but re-check the original suggestion:
# include "readSIMPLEControls.H" ... if (simple.found("convergence")) { ... } Check "readSIMPLEControls.H" file to see what is being read there and its relation to the following if (simple.found(..)) conditional. Again, I really don't wish to be impolite, but I really don't have enough time to help much more than I already did. Sorry but you need to do this alone (or keep some basic commercial support). /mark |
URF and convergence in natural convergence | Marie-Anne | Main CFD Forum | 11 | September 11, 2009 10:07 |
convergence RMS | anna | CFX | 7 | October 3, 2006 04:50 |
convergence | vijay | FLUENT | 6 | February 1, 2006 03:04 |
convergence | vijay | Main CFD Forum | 1 | January 30, 2006 13:13 |
too bad convergence | Davoche | Main CFD Forum | 2 | November 20, 2005 05:08 |
