After mapFields from ca
After mapFields from cavity to cavityFine I can not change the times in controlDict. There is the FoamXException: "Number 0.5 not of correct type" (startTime) at FoamX.Editors.DictionaryEntryEditor.EntryCache. ScalarCache.updateValue(ScalarCache.java:172) Should I show there ? Thank You for help. |
Search the forum. Then, set y
Search the forum. Then, set your locale to english - OpenFOAM does not like commas in number definition.
Hrv |
The explanation is in "Install
The explanation is in "Installation" and I had searched in "Preprocessing/FoamX".
Thank you Hrvoje |
