Home > Forums > OpenFOAM Pre-Processing
A doubt
Old   January 26, 2005, 04:44
Default Hi, I'm starting to study ho
Alberto Passalacqua (Alberto)
I'm starting to study how to write solvers using OpenFOAM.
Will my solver be available under FoamX, like icoFoam and others, or will I have to configure it manually?
Thanks in advance,
Alberto
Old   January 26, 2005, 06:06
Default Hello Alberto, you will ha
Mattijs Janssens (Mattijs)
Hello Alberto,
you will have to write configuration files (.cfg) yourself but that is fairly straightforward.
Take the config file (under $FOAMX_SYSTEM_CONFIG) of the application that behaves most like yours. Say I have written myFoam which is almost like icoFoam.
Take
$FOAMX_SYSTEM_CONFIG/applications/incompressible/icoFoam
and copy it to
$FOAMX_USER_CONFIG/applications/incompressible/myFoam
In there move the icoFoam.cfg to myFoam.cfg and make your changes.
Now create a case (right click on the root directory in the case browser) and voila you will have myFoam to choose from.
Old   January 26, 2005, 06:26
Default Thank you Mattijs. Regards
Thank you Mattijs.
Regards,
Alberto
Old   November 27, 2006, 07:51
Default Hej, I have problems with a
mss
Hej,
I have problems with adding a user application class.
When typing "echo $FOAM_USER_CONFIG" I just receive a empty line as
answer....?
Also if I type $FOAMX_SYSTEM_CONFIG/applications/incompressible/icoFoam
I get: No such file or directory
(I have OpenFoam solvers in the: OpenFOAM/OpenFOAM-1.3/applications/solvers)
What I should do to add my solver and in which path I should put it?
thank you,
Rita
Old   November 27, 2006, 14:21
Default Have a look at the (just updat
Mattijs Janssens
mattijs is on a distinguished road
Have a look at the (just updated)
http://openfoamwiki.net/index.php/Ho...olver_to_foamX
mattijs is offline   Reply With Quote
Old   November 28, 2006, 10:22
Default Hej, Thank you for the link.
mss
Hej,
Thank you for the link. Now I can choose my class in FoamX.
I have one question more:
After I did this changes as you sad. I wanted to recompile .C file.... why it gives error? (I didn't make changes, just name of files (.cfg and .C))
thank u for help.
Thread Tools
Trackbacks are On
Doubt Rishikesh FLUENT 0 February 24, 2009 04:32
doubt in B.C student Main CFD Forum 5 November 23, 2008 03:40
Doubt New User FLUENT 2 July 11, 2008 23:50
Doubt Mukund FLUENT 4 August 4, 2004 11:28
a doubt G.Balakrishnan FLUENT 0 November 27, 2000 02:48
