I have problems with adding a
I have problems with adding a user application class, so it is visible in FoamX. The application class is running fine, but I would like to use FoamX for preprocessing.
It must be something with placing some files and folders in $FOAMX_USER_CONFIG, but how should the structure be, so FoamX discovers the new application class??? |
The FOAMX_USER_CONFIG is trea
The FOAMX_USER_CONFIG is treated in the same way as the FOAMX_SYSTEM_CONFIG. Have a look at the files in $FOAMX_SYSTEM_CONFIG/applications (setup for Foam applications).
Take one of the application directories from under there, rename it and put it in a similar tree under $FOAMX_USER_CONFIG. Mattijs |
Thanks for the help! My appli
Thanks for the help! My application class is now visible in FoamX.
By the way, are you editing your source code in a simple text-editor or in Kdevelop. I miss a little overview over Foam even though the Doxygen documentation are provided. Rasmus Gjesing |
We use text editors and a lot
We use text editors and a lot of 'grep'ing through header files in $FOAM_SRC/foam/lnInclude. (I have an environment variable called 'I' set to that directory to save typing ;-)
Also all the other libraries in $FOAM_SRC (sampling, turbulenceModels, ...) can be searched in their lnInclude/ directory which contains links to all the source files. Thirdly I tend to program by example. Especially the utilities directory ($FOAM_UTILITIES) contains a lot of interesting code (for my purpose). Last but not least there is the documentation on the website (programmers guide) which can be terse but quite useful. Mattijs |
How to do this with version 1.
How to do this with version 1.2 ?
I did as Release Notes-1.2 tells, but can't make my own application visible in FoamX. ie. I can't creat a case with the user solver, because it is not in the application list. |
I want to make the appl
I want to make the application rhoSimpleFoam visible in FaomX. I Guess I can do somthing similar to what is stated in previus discusion under this topic but I dont know where the pathes $FOAMX_USER_CONFIG and FOAMX_SYSTEM_CONFIG points to. The big question is: How do I add this solver or alternativly create a case and modify it without the help of GUI. regards Erik |
There is a tutorial case for r
There is a tutorial case for rhoTurbFoam the equivalent transient solver. Copy the config files and initial fields from there, modify as necessary, change the time scheme to steadyState (fvSchemes) and add a SIMLPE entry and relaxation factors to fvSolutions (check the simpleFoam tutorial case to see what kind of stuff is needed).
Then you just run "rhoSimpleFoam <root> <case>", and it should work. |
Hello Erik!
One simple way
Hello Erik!
One simple way to find out about the paths: echo $FOAMX_USER_CONFIG on the shell shows you were it points to. Modifying cases is "easy" once you have understood chapter 4 of the user guide |
ok, thanks for the pointers fr
ok, thanks for the pointers from both of you. I will try do these modifications.
When typing "echo $FOAM_USER_CONFIG" I just receive a empty line as answer....? I will digg further down in problem. /Erik |
I have tried to copy the whole
I have tried to copy the whole turbFoam tutorial case "cavity" and I have done the modifications mentionded above. When trying to run the case I got the following error:
erik@compadre:~/OpenFOAM/erik-1.2/run/tutorials/rhoSimpleFoam$ rhoSimpleFoam . cavity /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : rhoSimpleFoam . cavity Date : Feb 28 2006 Time : 14:17:17 Host : compadre PID : 9361 Root : /home/erik/OpenFOAM/erik-1.2/run/tutorials/rhoSimpleFoam Case : cavity Nprocs : 1 Create time Create mesh for time = 0 Reading thermophysical properties Selecting thermodynamics package hThermo<puremixture<consttransport<speciethermo<hc onstthermo<perfectgas>>>>> Reading field U Reading/calculating face flux field phi --> FOAM FATAL IO ERROR : keyword pRefCell is undefined in dictionary "/home/erik/OpenFOAM/erik-1.2/run/tutorials/rhoSimpleFoam/cavity/system/fvSoluti on::SIMPLE" file: /home/erik/OpenFOAM/erik-1.2/run/tutorials/rhoSimpleFoam/cavity/system/fvSolutio n::SIMPLE from line 47 to line 47. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 152. FOAM exiting please tell me what I have done wrong or if there are more modifications that needs to be done. It would be nice to get it visible in FoamX but that might be to much to hope for with my limitations in OpenFAOM. Thanks /Erik |
never mind, I got the "pref" &
never mind, I got the "pref" & "pvalue" problem
Hello!
sorry for my frequen
Hello!
sorry for my frequent messaging, but im stuck!! I've managed to combine turbfoam and simplefoam tutorials cases to run rhosimplefoam. Now I need to go a step further and modify the code in rhosimplefoam (application) to handle incompressibe flow. Could anyone please give me a pointer of how or perhaps which files in rhosimplefoam that needs to be changed? kind regards |
Look in pEqn.H near the end. Y
Look in pEqn.H near the end. You will find rho being updated. Remove this line. Remember to fix rho to your constant value during initialization.
If you want to solve incompressible flow, why arent you just using simpleFoam? If you want the heat transfer capabilities of rhoSimpleFoam, a much better (and less costly) option would be to add a temperature or enthalpy transport equation to simpleFoam. |
Hi Eugene!
Thanks alot for
Hi Eugene!
Thanks alot for your quick respons! I have thought of both alternatives, but since I doent have much experiance with this software I might have made a bad decision in this subject. Im happy to hear you say that altering simpleFoam in the following way is easier because it has produced a seemingly correct flow description of what im trieng to modell. Which is modelling of flows inside a nuclear reactor. I will now try to edit the simpleFoam application insted. Thank you Erik |
This code I wrote for a temper
This code I wrote for a temperature transport equation might be useful. Just replace the rho field with a constant rho and remove the ddt(T) term for a steady solution.
//lookup Prt, k, R, p0 dimensionedScalar Prt = transportProperties.lookup("Prt"); dimensionedScalar p0 = transportProperties.lookup("p0"); dimensionedScalar R = transportProperties.lookup("R"); dimensionedScalar k = transportProperties.lookup("k"); dimensionedScalar Cp = transportProperties.lookup("Cp"); volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), p0/(T*R) ); Info << "Creating alphaEff." << endl; volScalarField alphaEff ( IOobject ( "alphaEff", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), turbulence().nut()()/Prt + k/(Cp*rho) ); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( fvm::ddt(T) + fvm::div(phi, T) - fvm::laplacian(alphaEff, T) ); } |
Thanks for your code and advic
Thanks for your code and advice!
I have modefied the code in the following way and included it in the end of my main code of my application: IOdictionary transportProperties ( IOobject ( "transportProperties", runTime.constant(), mesh, IOobject::MUST_READ, IOobject::NO_WRITE ) ); //lookup Prt, k, R, p0 dimensionedScalar Prt = transportProperties.lookup("Prt"); dimensionedScalar p0 = transportProperties.lookup("p0"); dimensionedScalar R = transportProperties.lookup("R"); dimensionedScalar k = transportProperties.lookup("k"); dimensionedScalar Cp = transportProperties.lookup("Cp"); volScalarField T ( IOobject ( "T", runTime.timeName(), mesh, IOobject::MUST_READ, IOobject::AUTO_WRITE ), mesh ); /* volScalarField rho ( IOobject ( "rho", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), p0/(T*R) ); */ double rho = 1000; Info << "Creating alphaEff." << endl; volScalarField alphaEff ( IOobject ( "alphaEff", runTime.timeName(), mesh, IOobject::NO_READ, IOobject::NO_WRITE ), turbulence().nut()()/Prt + k/(Cp*rho) ); for (int nonOrth=0; nonOrth<=nNonOrthCorr; nonOrth++) { solve ( fvm::div(phi, T) - fvm::laplacian(alphaEff, T) ); } ------------------------------------------------ It compiles whithout anyproblems but when I try to run my case with it I get the following error message: /*---------------------------------------------------------------------------*\ | ========= | | | \ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \ / O peration | Version: 1.2 | | \ / A nd | Web: http://www.openfoam.org | | \/ M anipulation | | \*---------------------------------------------------------------------------*/ Exec : hSimpleFoam . PD112 Date : Mar 10 2006 Time : 14:45:27 Host : compadre PID : 9547 Root : /home/erik/OpenFOAM/erik-1.2/run/tutorials/hSimpleFoam Case : PD112 Nprocs : 1 Create time Create mesh for time = 0 Reading field p Reading field U Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Selecting turbulence model kEpsilon Starting time loop Time = 0.1 BICCG: Solving for Ux, Initial residual = 0.99814, Final residual = 0.0339303, No Iterations 1 BICCG: Solving for Uy, Initial residual = 0.999487, Final residual = 0.0253859, No Iterations 1 BICCG: Solving for Uz, Initial residual = 1, Final residual = 0.0529838, No Iterations 1 ICCG: Solving for p, Initial residual = 1, Final residual = 0.00570935, No Iterations 183 time step continuity errors : sum local = 1.35731e-05, global = 8.6597e-10, cumulative = 8.6597e-10 --> FOAM FATAL IO ERROR : keyword Prt is undefined in dictionary "/home/erik/OpenFOAM/erik-1.2/run/tutorials/hSimpleFoam/PD112/constant/transport Properties" file: /home/erik/OpenFOAM/erik-1.2/run/tutorials/hSimpleFoam/PD112/constant/transportP roperties from line 27 to line 44. From function dictionary::lookupEntry(const word& keyword) const in file db/dictionary/dictionary.C at line 152. FOAM exiting ------------------------------------------------ I dont know what Ptr is or how to correctly add it to the transportProperties file. could anyone please give me a hint on what to do. Once again I apolegize for for insufficient programming knowlege. kind regards /Erik |
God morning!
Im experementi
God morning!
Im experementing with the code above and ran into a problem. when calculating "alphaeff" the dimensions doesnt match up in the following row: turbulence().nut()()/Prt + k/(Cp*rho) This calculation gives the following error message when running a case: --> FOAM FATAL ERROR : LHS and RHS of + have different dimensions dimensions : [0 2 -1 0 0 0 0] + [0 0 0 1 0 0 0] From function operator+(const dimensionSet& ds1, const dimensionSet& ds2) in file dimensionSet/dimensionSet.C at line 359. FOAM aborting I would be vary thankful for some help concerning how to modify alphaeff. regards /erik |
nut -> m^2/s
Prt -> dimension
nut -> m^2/s
Prt -> dimensionless nut/Prt = m^2/s = 0 2 -1 0 0 just make sure your input parameters k and Cp dimensions match and all will be well. as you can see now the dimensions of the RHS is Kelvin = 0 0 0 1 0 0 and if you dont know what the order of the dimensions are, its mass length time temperature ... N |
Hi Niklas
Thank U for the t
Hi Niklas
Thank U for the tip! Your recomendation worked well and now I can run my case. Im only confused about the dimension I had to set the Cp to. Because "turbulence().nut()()/Prt" has the dimension [0 2 -1 0 0 0 0] and k = [0 2 -2 0 0 0 0] and rho = [1 -3 0 0 0 0 0] which gives Cp = [-1 3 -1 0 0 0 0] =m³/(kg*s) for the equation to work. But some searching on the internet tells me that the dimension rather should be [0 2 -2 -1 0 0 0] = J/(kg*K) according to the homepage: http://physics.nist.gov/Pubs/SP811/sec04.html Do you know were my misstake lies? regards Erik |
Well, what if k is really kapp
Well, what if k is really kappa (Watt/(mK)) = m kg / ( s^3 K)?
I've never seen k (turbulent kinetic energy) before. cp is usually used with kappa/lambda http://www.cfd-online.com/OpenFOAM_D...part/happy.gif |
