Home > Forums > OpenFOAM Pre-Processing
FoamX problemcasebrowser
Old   July 26, 2006, 06:48
Default Hi! All I have 2 PCs (Here
tadashi
Hi! All
I have 2 PCs (Here I call these as A and B), and I could run OpenFOAM on both PCs as standalone.
But when I tryed to open the case of A from B by using FoamX, FoamX told me that it couldn't open the case.
I can access A to B by using ssh and "foamInstalationTest" also tell nothing wrong with setup.
Does someone help me?
I will show the log of console.
[tadashi@tmori oodles]$ Starting NameServer with inet:127.0.0.1:1234 ...
Starting FoamX Host Browser with inet:127.0.0.1:1234 ...
| \ / F ield | OpenFOAM: The Open Source CFD Toolbox |
| \ / O peration | Version: 1.3 |
| \ / A nd | Web: http://www.openfoam.org |
| \/ M anipulation | |
Exec : FoamXHostBrowser
Date : Jul 26 2006
Time : 19:38:51
Host : tmori
PID : 28999
Root :
Case :
Nprocs : 1
HostBrowser running.....
Using jar /home/tadashi/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/l ib/FoamX.jar
Using jar /home/tadashi/OpenFOAM/OpenFOAM-1.3/applications/utilities/preProcessing/FoamX/l ib/jlfgr-1_0.jar
Warning: Cannot convert string "-watanabe-mincho-medium-r-normal--*-140-*-*-c-*-jisx0208.1983-0" to type FontStruct
Doing (with timeout 0) : "ssh panoutsosvisitor -l tadashi FoamXCaseBrowser -ORBNamingAddr inet:127.0.0.1:1234 &"
Exec : FoamXCaseBrowser
Date : Jul 26 2006
Time : 11:39:22
Host : panoutsosvisitor
PID : 2226
Root :
Case :
Nprocs : 1
Finishing FoamXCaseBrowser::main(int argc, char **argv)
Caught FoamXError exception in FoamXCaseBrowser::main(int argc, char **argv) :
FoamXError "Unexpected error"
In function "FoamX::NameServer::connect(CORBA:RB_ptr pOrb)"
in file "NameServer.C" at line 220
FoamX.Exceptions.FoamXException: No caseBrowser started on panoutsosvisitor
at FoamX.CaseManagement.CaseBrowserModel.getCaseBrows erReference(CaseBrowserModel.j ava:415)
at FoamX.CaseManagement.CaseBrowserModel.startCaseBro wser(CaseBrowserModel.java:458 )
at FoamX.CaseManagement.CaseBrowserPanel$StartCaseBro wserAction.actionPerformed(Cas eBrowserPanel.java:1607)
at FoamX.CaseManagement.CaseBrowserPanel.handleMouseO pen(CaseBrowserPanel.java:1383 )
at FoamX.CaseManagement.CaseBrowserPanel.OnMouseClick ed(CaseBrowserPanel.java:1246)
at FoamX.CaseManagement.CaseBrowserPanel.access$200(C aseBrowserPanel.java:69)
at FoamX.CaseManagement.CaseBrowserPanel$2.mouseClick ed(CaseBrowserPanel.java:1149)
at java.awt.AWTEventMulticaster.mouseClicked(AWTEvent Multicaster.java:211)
at java.awt.Component.processMouseEvent(Component.jav a:5103)
at java.awt.Component.processEvent(Component.java:489 7)
at java.awt.Container.processEvent(Container.java:156 9)
at java.awt.Component.dispatchEventImpl(Component.jav a:3615)
at java.awt.Container.dispatchEventImpl(Container.jav a:1627)
at java.awt.Component.dispatchEvent(Component.java:34 77)
at java.awt.LightweightDispatcher.retargetMouseEvent( Container.java:3483)
at java.awt.LightweightDispatcher.processMouseEvent(C ontainer.java:3207) at java.awt.LightweightDispatcher.dispatchEvent(Conta iner.java:3128)
at java.awt.Container.dispatchEventImpl(Container.jav a:1613)
at java.awt.Window.dispatchEventImpl(Window.java:1606 )
at java.awt.EventQueue.dispatchEvent(EventQueue.java: 456)
at java.awt.EventDispatchThread.pumpOneEventForHierar chy(EventDispatchThread.java:2 01)
at java.awt.EventDispatchThread.pumpEventsForHierarch y(EventDispatchThread.java:151 )
at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:145) at java.awt.EventDispatchThread.pumpEvents(EventDispa tchThread.java:137) at java.awt.EventDispatchThread.run(EventDispatchThre ad.java:100)
/home/tadashi/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 131: 28999 abort FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 28995).
/home/tadashi/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 66: 28995 abort nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
Old   July 27, 2006, 04:35
Default The problem could be the 127.0
Mattijs Janssens
mattijs is on a distinguished road
The problem could be the 127.0.0.1 instead of the hostname. Do not use 'localhost' and/or change your /etc/hosts.
mattijs is offline   Reply With Quote
Old   July 27, 2006, 05:54
Default Hi! Mattijs Thank you for y
tadashi
Hi! Mattijs
Thank you for your suggestion, but I still have same problem as below. Do you have any other idea?
Tadashi
[tadashi@tmori oodles]$ Starting NameServer with inet:tmori:1234 ...
Starting FoamX Host Browser with inet:tmori:1234 ...
Date : Jul 27 2006
Time : 19:54:55
Host : tmori
PID : 11935
Root :
Case :
Nprocs : 1
Doing (with timeout 0) : "ssh panoutsosvisitor -l tadashi FoamXCaseBrowser -ORBNamingAddr inet:tmori:1234 &"
Date : Jul 27 2006
Time : 11:55:19
PID : 7967
Root :
Case :
Nprocs : 1
in file "NameServer.CFinishing FoamXCaseBrowser::main(int argc, char **argv)
" at line 220
at java.awt.AWTEventMulticaster.mouseClicked(AWTEvent Multicaster.java:211) at java.awt.AWTEventMulticaster.mouseClicked(AWTEvent Multicaster.java:211) at java.awt.Component.processMouseEvent(Component.jav a:5103)
/home/tadashi/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 131: 11935 aborted FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB: Killing name server nsd(pid 11933).
/home/tadashi/OpenFOAM/OpenFOAM-1.3/bin/runFoamXHB: line 66: 11933 aborted nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
Old   July 28, 2006, 12:15
Default Works for me. Running hostb
Mattijs Janssens
Works for me.
Running hostbrowser on a macine 'hunt', starting casebrowser on 'dm':
Doing (with timeout 0) : "ssh dm -l mattijs FoamXCaseBrowser -ORBNamingAddr inet:hunt:1234 &"
CaseBrowser running.....
Guess your panoutsosvisitor machine does not 'know' tmori (from the nameserver address inet:tmori:1234) or the port 1234 is already taken.
Old   July 31, 2006, 10:16
Default Dear Mattijs Thanks for you
tadashi
Dear Mattijs
Thanks for your reply.
I changed port from 1234 to another by changing the file ~/OpenFOAM/.OpenFOAM-1.3/apps/FoamX/FoamXClient.cfg and also checked host name by pinging.
But still I have same problem, only one thing that I found is that "echo $HOST" reply nothing.
Does it make problem and what can I do for, if it makes problem?
Old   August 1, 2006, 12:28
Default You will need a valid hostname
Mattijs Janssens
You will need a valid hostname and a single entry in /etc/hosts for it.
E.g. if I grep for my machine:
grep hunt /etc/hosts
I get:
10.0.0.159 hunt hunt.opencfd.co.uk
Old   August 1, 2006, 13:19
Default Dear Mattijs Yep, When I c
tadashi
Dear Mattijs
Yep,
When I checked as you said, it showed as below.
grep tmori /etc/hosts
I got
***.198.69.210 tmori
(I just hide first 3 digit )
Old   August 2, 2006, 01:56
Default Check the ns.ref that gets wri
Mattijs Janssens
Check the ns.ref that gets written by nsd (inside the runFoamXHB script). Check that both computers can read it. Check the contents with iordump or iordecode (I forget which). Check the machine name in there (has to be exactly the same as the machine in /etc/hosts, including domain name).
Old   August 2, 2006, 04:28
Default Dear Mattijs I checked the
tadashi
Dear Mattijs
I checked the contents of ns.ref by using iordump.
Does something wrong with it, please refer as below?
Repo Id: IDL:omg.org/CosNaming/NamingContextExt:1.0
IIOP Profile
Version: 1.0
Address: inet:***.198.69.210:1234
Key: 4e 61 6d 65 53 65 72 76 69 63 65 NameService
Multiple Components Profile
Components: Native Codesets:
normal: ISO 8859-1:1987; Latin Alphabet No. 1
wide: ISO/IEC 10646-1:1993; UTF-16, UCS Transformation Format 16-bit form
Key: (empty)
Old   August 18, 2006, 06:44
Default Dear Mattijs At last, I cou
tadashi
Dear Mattijs
At last, I could solve the problem.
The problem was just the FIREWALL setting.
Thanks a lot of your advices.
Thread Tools
Trackbacks are On
About FoamX ivanyao OpenFOAM Installation 2 September 21, 2008 21:24
FoamX error derath OpenFOAM Pre-Processing 2 April 25, 2007 05:51
FoamX ianz8802 OpenFOAM Installation 2 March 9, 2007 00:45
FoamX Issues tger003 OpenFOAM Pre-Processing 0 January 18, 2007 15:50
Run FoamX ghazi OpenFOAM Pre-Processing 7 July 9, 2006 14:48
