-   OpenFOAM Pre-Processing (https://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Run FoamX (https://www.cfd-online.com/Forums/openfoam-pre-processing/62182-run-foamx.html)
ghazi July 5, 2006 09:50
I have installed OpenFOAM 1.2,
I have installed OpenFOAM 1.2, Installation is ok, but when I try to start FoamX I receive this error:
[ghazi@ghazi ~]$ FoamX
Starting NameServer with inet:ghazi:1234 ...
Starting FoamX Host Browser with inet:ghazi:1234 ...
Exec : FoamXHostBrowser
Date : Jul 05 2006
Time : 14:12:12
Host : ghazi
PID : 4605
Root :
Case :
Nprocs : 1
HostBrowser running.....
Using jar /home/ghazi/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib /FoamX.jar
Using jar /home/ghazi/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib /jlfgr-1_0.jar
FoamX.Exceptions.FoamXException: Default name service could not be contacted.
at FoamX.App.initialiseHostBrowser(App.java:512)
at FoamX.App.initialise(App.java:343)
at FoamX.App.main(App.java:186)
Has anyone an idea to solve this?
msrinath80 July 5, 2006 13:42
See the solutions for this pro
See the solutions for this problem posted in this very same forum. Use the 'Search' option on the left hand side.
Use "Default name service could not be contacted" as your keyword (include the double quotes).
ghazi July 6, 2006 02:57
hi ,thanks . But I didn't fin
hi ,thanks .
But I didn't find any think , can you help me more
msrinath80 July 6, 2006 09:02
http://www.cfd-online.com/Ope
[1] http://www.cfd-online.com/OpenFOAM_D...ages/1/54.html
[2] http://www.cfd-online.com/OpenFOAM_D...ges/1/654.html
[3] http://www.cfd-online.com/OpenFOAM_D...ages/1/39.html
[4] http://www.cfd-online.com/OpenFOAM_D...es/1/1767.html
Hope that helps http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
ghazi July 9, 2006 00:38
Hi pul , thanks very much for
Hi pul , thanks very much for your help
msrinath80 July 9, 2006 00:40
No problem. If one of those so
No problem. If one of those solutions works for you please post a message stating how you solved it. It will be useful for someone facing similar problems.
Cheers http://www.cfd-online.com/OpenFOAM_D...part/happy.gif
ghazi July 9, 2006 06:17
yes number 4 , turn off the S
yes number 4 ,
turn off the SELinux security (and reboot), FoamX will work. Desktop->System settings->Security Level.
msrinath80 July 9, 2006 14:48
Thank you. Much appreciated!!!
