Undefined internal faces becoming default patches |
June 16, 2006, 10:16 |
You didn't match the block fac
Hrvoje Jasak
Rep Power: 33 |
You didn't match the block faces properly. Uncovered block faces are shown below:
BTW, this should really go into the meshing thread because it's nothing to do with FoamX. Hrv
June 16, 2006, 10:25 |
I can see the image, but I'm c
trevor j stittleburg
I can see the image, but I'm confused as to what exactly isn't matching up.
Does it have to do with my vertices not being aligned so the blocks aren't touching, or does it have to do with dividing the blocks into cells (because I used (20 20 20) for each one)? Do I need to align each cell of each block? If I have to do that, with my geometry I would need to use a ratio of whole numbers something like 16:600 something:4703, etc, a much too large mesh to run. |
[Gmsh] Internal faces from gmsh how to create patches in OpenFoam | podallaire | OpenFOAM Meshing & Mesh Conversion | 27 | April 25, 2012 21:24 |
[Gmsh] Default Faces on Boundary Layer | axel | OpenFOAM Meshing & Mesh Conversion | 8 | February 17, 2011 07:47 |
Salome creating patches within faces | hoogland | OpenFOAM Pre-Processing | 1 | November 8, 2007 01:51 |
[Gmsh] GmshToFoam undefined faces | derath | OpenFOAM Meshing & Mesh Conversion | 7 | May 22, 2006 04:54 |
[Gmsh] Undefined faces in mesh | derath | OpenFOAM Meshing & Mesh Conversion | 1 | May 13, 2006 06:57 |
