Setting rootcase variable
Old   May 8, 2006, 14:22
Default Hi, I'm trying to use the out
Carlo Fabrizi
carlo_fabrizi is on a distinguished road
I'm trying to use the output of one case as bc of another one.. It is a terrible task, now I need to know how I can change variable environment in a function that i use to read data.. in particular I run a modified simpleFoam as:
simpleRFR <root> <case1>
and I can read data from the directory /<case1>/0/.
But in simpleRFR.C I call a function that should read from /<case2>/5/. How i can do this??
I read data in the following way:
// Get index of patch
label inletPatchID = mesh.boundaryMesh().findPatchID("movingWall");
// Get reference to boundary value
const fvPatchVectorField& faceCentreshub = mesh.Cf().boundaryField()[inletPatchID];
fvPatchVectorField& movingWallU = U.boundaryField()[inletPatchID];
thanks
Bye
carlo_fabrizi is offline   Reply With Quote
RP_Set_Real("variable-name", variable name) bohis FLUENT 1 March 9, 2009 07:44
Setting working environment variable Arthur FLUENT 0 December 10, 2008 04:33
B.C. setting PK FLUENT 0 September 28, 2007 03:46
setting variable boundary Mehdi Siemens 3 January 31, 2006 04:33
variable time step:setting global courant number Cedric FLUENT 0 July 28, 2005 09:14
