constant heat flux
Old   March 13, 2011, 18:52
Default constant heat flux
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hey all,
i always use a constant wall temperature to create my bc condition.
so the question is if i can use a constant wall heat flux like that way:
file T
hot_wall
type constantWallHeatFlux;
heatFlux uniform 23; // [W]
best regards
Tobi
Tobi is offline   Reply With Quote
Old   March 14, 2011, 04:29
akidess's Avatar
Anton Kidess
Specifying a fixedGradient should be equivalent to a heat flux. You just need the proper scaling:
q = k * grad(T) <-> grad(T) = q/k;
problem with constant wall heat flux openfoam1 OpenFOAM 6 January 13, 2019 08:18
HOW TO APPLY CONSTANT HEAT FLUX OVER WALL OF TUBE K.VENKATACHALAPATHI FLUENT 6 December 28, 2015 05:58
How to set a initial temperature and constant heat flux at same BC's?? Jane FLUENT 4 October 25, 2015 12:01
Constant heat flux ocy FLUENT 1 January 17, 2005 01:54
constant Heat flux at the wall hatta FLUENT 2 January 9, 2004 07:13
