-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Steadystate incompressible laminar Newtonianfluids solver (http://www.cfd-online.com/Forums/openfoam-pre-processing/62213-steadystate-incompressible-laminar-newtonianfluids-solver.html)
anja January 27, 2006 10:01
Hi, does someone know, whet
does someone know, whether there is a solver for:
steady-state, incompressible, laminar, Newtonian-fluids
Thanks a lot,
Anja
eugene January 27, 2006 10:34
Sure, just run simpleFoam and
Sure, just run simpleFoam and switch the turbulence model to laminar.
anja January 27, 2006 15:34
And how do I have to do that?
And how do I have to do that? (I really can need the advice)
Thanks again
anja January 27, 2006 15:38
And what about the change from
And what about the change from non-Newtonian fluids of simpleFoam to Newtonian fluids?
eugene January 28, 2006 05:15
simpleFoam uses Newtonian flui
simpleFoam uses Newtonian fluid by default.
Open the "turbulenceProperties" file in the "constant" sub-directory and change the turbulence model from "RNGkEpsilon" to "laminar".
anja February 1, 2006 09:33
And afterwards turbulence off?
And what about all the other files in which parameters for the turbulent calculation are used?
eugene February 1, 2006 09:58
Sure switch turbulence off if
Sure switch turbulence off if you like. The rest should just work.
brooksmoses February 1, 2006 21:24
As an alternate solution, I en
As an alternate solution, I ended up writing a small variant of simpleFoam for my own work that does exactly what you want -- incompressible, Newtonian, steady-state, laminar flow -- without any additional "features" like turbulence or viscosity models.
It's a pretty trivial combination of parts from the existing OpenFOAM applications, so I can't really claim any ingenuity in creating it, but to save you the trouble of recreating it I've put a copy online here: http://dpdx.net/software/openfoam/st...w_1.0.0.tar.gz .
There's a README.txt file in the .tar.gz file that covers what bits go where to install it.
anja February 23, 2006 10:09
Okay, one more question on tha
Okay, one more question on that topic.
Why do I need a time-step for a steady-state solver?
hjasak February 23, 2006 10:17
It's not a time step, just an
It's not a time step, just an iteration counter - you can set the deltaT to whatever you like. I usually use 1.
Enjoy,
Hrv
anja March 23, 2006 06:43
Hi, I'm still using simpleF
I'm still using simpleFoam as laminar solver. The problem is that the calculation takes that long. I've already changed the solver for p to AMG.
Is there any suggestion for the endtime in the controldict?
