Steadystate incompressible laminar Newtonianfluids solver |
January 27, 2006, 09:01 |
does someone know, whet
Anja Stretz
does someone know, whether there is a solver for: steady-state, incompressible, laminar, Newtonian-fluids Thanks a lot, Anja |
January 27, 2006, 09:34 |
Sure, just run simpleFoam and
Eugene de Villiers
Rep Power: 21 |
Sure, just run simpleFoam and switch the turbulence model to laminar.
January 27, 2006, 14:34 |
And how do I have to do that?
Anja Stretz
And how do I have to do that? (I really can need the advice)
Thanks again |
January 27, 2006, 14:38 |
And what about the change from
Anja Stretz
And what about the change from non-Newtonian fluids of simpleFoam to Newtonian fluids?
January 28, 2006, 04:15 |
simpleFoam uses Newtonian flui
Eugene de Villiers
Rep Power: 21 |
simpleFoam uses Newtonian fluid by default.
Open the "turbulenceProperties" file in the "constant" sub-directory and change the turbulence model from "RNGkEpsilon" to "laminar". |
February 1, 2006, 08:33 |
And afterwards turbulence off?
Anja Stretz
And what about all the other files in which parameters for the turbulent calculation are used? |
February 1, 2006, 08:58 |
Sure switch turbulence off if
Eugene de Villiers
Rep Power: 21 |
Sure switch turbulence off if you like. The rest should just work.
February 1, 2006, 20:24 |
As an alternate solution, I en
As an alternate solution, I ended up writing a small variant of simpleFoam for my own work that does exactly what you want -- incompressible, Newtonian, steady-state, laminar flow -- without any additional "features" like turbulence or viscosity models.
It's a pretty trivial combination of parts from the existing OpenFOAM applications, so I can't really claim any ingenuity in creating it, but to save you the trouble of recreating it I've put a copy online here: http://dpdx.net/software/openfoam/st...w_1.0.0.tar.gz . There's a README.txt file in the .tar.gz file that covers what bits go where to install it. |
February 23, 2006, 09:09 |
Okay, one more question on tha
Anja Stretz
Okay, one more question on that topic.
Why do I need a time-step for a steady-state solver? |
February 23, 2006, 09:17 |
It's not a time step, just an
Hrvoje Jasak
Rep Power: 33 |
It's not a time step, just an iteration counter - you can set the deltaT to whatever you like. I usually use 1.
Enjoy, Hrv
March 23, 2006, 05:43 |
I'm still using simpleF
#11 |
Anja Stretz
I'm still using simpleFoam as laminar solver. The problem is that the calculation takes that long. I've already changed the solver for p to AMG. Is there any suggestion for the endtime in the controldict? |
June 27, 2021, 23:34 |
Hellow
#12 |
rameshkumar m bhoraniya
This file is not available here. can you email on rameshbhoraniya@gmail.com |
Steadystate Incompressible Flow with Heat Transfer | johanzietsman | OpenFOAM Running, Solving & CFD | 3 | August 31, 2021 09:11 |
Solver incompressible oil steadystate heat transfer in walls | alki | OpenFOAM Running, Solving & CFD | 0 | March 13, 2009 07:57 |
Steadystate Vs Transient solver | amitshah | OpenFOAM Running, Solving & CFD | 1 | August 23, 2006 02:54 |
Steadystate Euler solver | jelmer | OpenFOAM Running, Solving & CFD | 1 | June 19, 2006 08:24 |
Slow convergence in steadystate incompressible simpleFoam suggestions | brooksmoses | OpenFOAM Running, Solving & CFD | 0 | March 3, 2006 04:57 |
