Problem running paraFoam paraview command not found
Old   December 3, 2005, 23:52
Default I'm trying to run paraFoam, bu
spdracer22
I'm trying to run paraFoam, but am getting the error:
<path>/paraFoam: line 57: paraview: command not found
I'm running the latest version of OpenFoam on Fedora Core 4. Any help is greatly appreciated.
Thanks,
Justin
Old   December 4, 2005, 00:57
Default I found the fix... I edited th
spdracer22
I found the fix... I edited the "ParaView_INST_DIR" variable in the bashrc file in $HOME/OpenFoam/OpenFOAM-1.2/.OpenFOAM-1.2/apps/paraview.
Old   December 7, 2005, 05:32
Default Hi, Justin! What did you edit
Efimenko Evgenii
evgenii is on a distinguished road
Hi, Justin!
What did you edit?
How did you change this entry?
I'm interested in this, because I've faced the same problem.
Thank you.
evgenii is offline   Reply With Quote
[OpenFOAM] ParaView command not found joey ParaView 12 January 18, 2021 05:38
[OpenFOAM] Problem with paraview and paraFoam openfoam_user ParaView 36 May 13, 2014 07:37
[OpenFOAM] Paraview command not found hardy ParaView 7 September 18, 2008 04:59
Problem of compilation OF 14Allwmake command not found erik_d OpenFOAM Bugs 13 September 13, 2008 21:45
Error starting paraFoam line 67 paraview command not found jango OpenFOAM Installation 4 July 19, 2007 01:39
