STL build of a file in MATLAB
Old   February 9, 2015, 13:27
Default STL build of a file in MATLAB
Steven Jachec
sjachec is on a distinguished road
I have created a 3D Gaussian bump geometry in MATLAB. I am want to generate steady flow around the bump using simpleFoam. Wanting to bring it into snappyHexMesh, I used stlwrite to produce the STL file and bring to the triSurface directory.
After I blockMesh and snappyHexMesh, I can see in paraview it is meshing through my Gaussian bump, which I do not want. Is this because the STL is not closed (I did a surfaceCHeck and can see it is not)? I thought the bounding box limits would take care of this. MATLAB basically produces a single valued function of the bump. If this is the problem, what's the best/easiest way to close?
sjachec is offline   Reply With Quote
Old   February 9, 2015, 14:59
anonymous
ssss is on a distinguished road
You will also need to create an stl with the full domain containing the bump so that snappyHexMeshDict can mesh inside a closed domain
ssss is offline   Reply With Quote
Old   February 9, 2015, 16:02
Steven Jachec
But the motorbike example does not do this. The motorbike OBJ is just bike and rider itself. We then use blockMeshDict to set the xyz limits of the bounding box and mesh around the OBJ. Correct?
Old   February 9, 2015, 16:47
anonymous
Yes that is true.
If you only want to use one *.stl or one *.obj, you will need to be very careful with the position set in the *.stl, you will need to set the stl as a refinementSurface , and you will need to set a correct locationInMesh
If you want I can have a look at your case to see if I can obtain your mesh
Old   February 12, 2015, 13:15
Smile
Steven Jachec
I figured it out. The (snappyHexMesh [SHM]) gridding turned out to be fine.
The issue was.....
After SHM additional folders (1/ 2/ 3/) are created. I failed to copy the newly gridded results back to polyMesh directory. I fixed by
>> mv 3/polyMesh/* constant/polyMesh
Thanks for your offer to look,
Steven
matlab, snapphexmesh, stl
[swak4Foam] swak4foam building problem GGerber OpenFOAM Community Contributions 54 April 24, 2015 16:02
[swak4Foam] swak4Foam-groovyBC build problem zxj160 OpenFOAM Community Contributions 18 July 30, 2013 13:14
"parabolicVelocity" in OpenFoam 2.1.0 ? sawyer86 OpenFOAM Running, Solving & CFD 21 February 7, 2012 11:44
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 19:08
DxFoam reader update hjasak OpenFOAM Post-Processing 69 April 24, 2008 01:24
