FvSolution pRefCell and pRefValue
Like Tree39Likes
  • 21 Post By hjasak
  • 18 Post By ArathoN
Old   October 17, 2005, 04:54
Default Can any one explain a little a
Maka Mohu
maka is on a distinguished road
Can any one explain a little about how to set pRefCell and pRefValue in fvSolution dictionary since they have been introduced in 1.2.
I changed the mesh for channelOodles and I got a warning message about pRefCell. Thanks.
PISO
nCorrectors 2;
nNonOrthogonalCorrectors 0;
pRefCell 1001;
pRefValue 0;
Regards,
Maka.
maka is offline   Reply With Quote
Old   October 18, 2005, 11:10
Default If you have an incompressible
Hrvoje Jasak
hjasak will become famous soon enough
If you have an incompressible flow in a domain where none of the boundaries uses a fixed value (or similar) boundary condition, the value of the pressure in the system is indeterminate to a constant. Iterative solvers dont like that because the solution can jump and down, so we need to do tricks to make sure it does not happen.
The way to do this is to specify the pressure level in one cell. Previously, this used to be cell zero with value zero and hard-coded in the solver, but this causes trouble when the cell is next to a coupled boundary. The new entries allow you to control in which cell the pressure is given and to which level.
Hrv
pyt, styleworker, CarCin and 18 others like this.
Hrvoje Jasak
Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk
hjasak is offline   Reply With Quote
Old   April 30, 2009, 15:44
Suraj Deshpande
suraj is on a distinguished road
What is done with pdRefCell and pdRefValue when atleast one of the boundaries has a a fixed value of pressure specified? Is pdRefValue still used then?
Thanks,
Suraj
suraj is offline   Reply With Quote
Old   October 15, 2014, 05:19
Nicole Andrew
Nicole is on a distinguished road
Hi Suraj,
I see this is a very old post, but did you ever find an answer to your question bout the fixed boundary pressure?
Thanks,
Nicole
Nicole is offline   Reply With Quote
Old   October 22, 2014, 14:17
ArathoN
ArathoN is on a distinguished road
Originally Posted by Nicole View Post
Hi Suraj,
Thanks,
Nicole
You need to see the solver files and code. In the case of PIMPLE, they are first initialized to zero then it is used a look-up function to scrape their values from fvsolution
from createFields.H
label pRefCell = 0;
scalar pRefValue = 0.0;
setRefCell(p, mesh.solutionDict().subDict("PIMPLE"), pRefCell, pRefValue);
Now if you look at the pEqn.H file, in the pressure corrector loop:
    fvScalarMatrix pEqn
        fvm::laplacian(rAUf, p) == fvc::div(phiHbyA)
    pEqn.setReference(pRefCell, pRefValue);
    pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter())));
And here it is used the referenced pressure.
IMO if there is no declaration of pRefCell or pRefValue in pimple they will not created by createFields.H
So in case of a well-conditioned problem with dirichlet (or mixed) pressure BC, the pRefValue should not be considered.
EDIT: at fvCFD.H included in pimplefoam you'll find the findRefCell.C where it is defined the serRefCell function:
if (fieldRef.needReference() || forceReference)
So if there is a need to define a reference pressure it will be used otherwise they are neglected.However i can't find where ".needReference()" is define, whis is the function that will tell the solver if it needs or not pRefCell. If i found out something i'll update the post.
EDIT2: I've found it, the function "needReference" is defined GeometricField.C as such:
bool Foam::GeometricField<Type, PatchField, GeoMesh>::needReference() const
  // Search all boundary conditions, if any are
  // fixed-value or mixed (Robin) do not set reference level for solution.
  bool needRef = true;
  forAll(boundaryField_, patchi)
  if (boundaryField_[patchi].fixesValue())
  needRef = false;
  break;
  reduce(needRef, andOp<bool>());
  return needRef;
Now you have the complete picture of how the "referencing process" works on OF.
ArathoN is offline   Reply With Quote
Old   February 17, 2015, 03:00
Nicole Andrew
Thank you so much for your well-explained response. Sorry for only replying now, but we did find your response very useful!
Periodic pressure in turb channel pRefCell maka OpenFOAM Running, Solving & CFD 14 October 21, 2010 09:02
General help for fvSchemes and fvSolution settings harly OpenFOAM Running, Solving & CFD 4 September 7, 2009 10:31
Programmatically create fvSolution dictionary cliffoi OpenFOAM Running, Solving & CFD 14 February 12, 2009 02:50
What must be defined in fvSolution Marco Kupiainen (Kupiainen) OpenFOAM Running, Solving & CFD 1 February 21, 2005 05:03
