-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   Adding new class in version 12 (http://www.cfd-online.com/Forums/openfoam-pre-processing/62263-adding-new-class-version-12-a.html)
billy October 8, 2005 16:08
I was trying to add a new clas
I was trying to add a new class following steps:
http://www.cfd-online.com/OpenFOAM_D...tml?1085564396
and
http://openfoamwiki.net/index.php/Howto_adding_a_ new_solver_to_foamX
but $FOAMX_SYSTEM_CONFIG and $FOAMX_USER_CONFIG are not defined.
Also there seems to be a change in structure comparing 1.1 and 1.2.
was: OpenFOAM-1.1/applications/utilities/preProcessing/FoamX/config/applications
now: OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/???
I created myFoam class using interFoam and copied it from:
$HOME/OpenFOAM/OpenFOAM-1.2/applications/solvers/multiphase/interFoam
to:
$WM_PROJECT_USER_DIR/applications/solvers/myFoam
My question is which configuration file do I edit see it in FoamX?
Thank you very much,
Billy.
mattijs October 10, 2005 04:47
Check out the ReleaseNotes-1.2
Check out the ReleaseNotes-1.2 in the installation.
In your case I think you need to have myFoam/FoamX/myFoam.cfg.
