Trying to run FoamX, all env p
Trying to run FoamX, all env paths seem to be ok, Java works fine on this computer, and here's what I get
==================================== HostBrowser running..... Using jar /home/dima/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib/ FoamX.jar Using jar /home/dima/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib/ jlfgr-1_0.jar Error: could not find libjava.so Error: could not find Java 2 Runtime Environment. /home/dima/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 131: 5440 Killed FoamXHostBrowser -ORBNamingAddr $myIOP runFoamXHB : cleanup runFoamXHB: Killing name server nsd(pid 5436). /home/dima/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 1: 5436 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null ============================== Anyone had same problem? Any ideas? |
Did you remember to install ja
Did you remember to install java in the correct place? Eg if you have installed FOAM in the directory ~/OpenFOAM/ then you should have a subdirectory under there called "linux" (assuming that is your platform) which should have the java runtime environment, gcc and paraview installed in it.
Check that you've installed the "third party binaries" correctly (they are on the download page) |
