Another Java error
Old   September 22, 2005, 12:36
Default Trying to run FoamX, all env p
Dmitry Kondratenko
drungarius is on a distinguished road
Trying to run FoamX, all env paths seem to be ok, Java works fine on this computer, and here's what I get
HostBrowser running.....
Using jar /home/dima/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib/ FoamX.jar
Using jar /home/dima/OpenFOAM/OpenFOAM-1.2/applications/utilities/preProcessing/FoamX/lib/ jlfgr-1_0.jar
Error: could not find libjava.so
Error: could not find Java 2 Runtime Environment.
/home/dima/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 131: 5440 Killed FoamXHostBrowser -ORBNamingAddr $myIOP
runFoamXHB : cleanup
runFoamXHB: Killing name server nsd(pid 5436).
/home/dima/OpenFOAM/OpenFOAM-1.2/bin/runFoamXHB: line 1: 5436 Killed nsd -ORBIIOPAddr $myIOP --ior $FOAMX_CONFIG/ns.ref </dev/null
Anyone had same problem? Any ideas?
drungarius is offline   Reply With Quote
Old   October 6, 2005, 19:31
Default Did you remember to install ja
Ron W Cresswell
roncresswell is on a distinguished road
Did you remember to install java in the correct place? Eg if you have installed FOAM in the directory ~/OpenFOAM/ then you should have a subdirectory under there called "linux" (assuming that is your platform) which should have the java runtime environment, gcc and paraview installed in it.
Check that you've installed the "third party binaries" correctly (they are on the download page)
roncresswell is offline   Reply With Quote
Java home how to basilwatson OpenFOAM Installation 1 April 28, 2008 08:37
Java error while starting FoamX erydj OpenFOAM Pre-Processing 2 May 4, 2007 08:53
Java error while starting FoamX cfdengineering OpenFOAM Pre-Processing 16 June 28, 2006 20:02
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 04:18
java vs c++ zxaar Main CFD Forum 10 December 3, 2004 02:05
