Whatbs best way to create new case
Old   June 19, 2005, 22:32
Default How to best create a new case?
jvn
John Van Norman
jvn is on a distinguished road
How to best create a new case? I created a new case using FoamX by right-clicking on $FOAM_RUN/sonicFoam and creating new case. In the lower window, I get:
Case /home/john/OpenFOAM/john-1.1/run/tutorials/sonicFoam/cube saved successfully to time 0
When I look into $FOAM_RUN/tutorials/sonicFoam, however, the directory has not been created. Not sure how to correct this. If it means anything, I'm running on FC3 x86_64 but not with the AMDx86_64 OpenFOAM... I had difficulty getting the latter to testInstallation properly.
Any suggestions would be much appreciated.
Cheers,
JVN
jvn is offline   Reply With Quote
Old   June 20, 2005, 15:31
Default Are /home/john/OpenFOAM/john-1
Mattijs Janssens
mattijs is on a distinguished road
Are /home/john/OpenFOAM/john-1.1/run/tutorials/sonicFoam/cube and $FOAM_RUN/tutorials/sonicFoam exactly the same directory?
Does 'FoamXCaseServer' get started with the '-create' option? I get something like
FoamXCaseServer /home/pinky2/mattijs/OpenFOAM/mattijs-1.1/run/rhoSonicFoam junk -create rhoSonicFoam
mattijs is offline   Reply With Quote
Old   June 20, 2005, 22:19
Default You're right... I had "misplac
jvn
John Van Norman
You're right... I had "misplaced" the new cases by looking for them by typing 'tut' at the command line, which took me somewhere else. Sorry for that.
JVN
Whatbs the meaning of variables in the computed results yfjma OpenFOAM Post-Processing 8 November 12, 2012 02:52
FoamX Create new case jam OpenFOAM Running, Solving & CFD 1 January 17, 2008 13:10
[OpenFOAM] Whatbs the best way to visualize paticles from lagrangian solvers sek ParaView 2 September 19, 2007 18:02
Create Case from a terminal gruber2 OpenFOAM Running, Solving & CFD 2 June 10, 2007 13:45
I have a Problem to create new Case lange OpenFOAM Pre-Processing 1 June 24, 2005 16:41
