[Sponsors] | |||||
The R condition is defined in tutorials/rhoTurbFoam/cavity FoamX, but I found it isn't uesed in the solver. why is it defined ?Someone can answer me.
Thanks. |
Niklas Nordin
Rep Power: 12 ![]() |
You found it isn't used?
in the UEqn.H, what is this then, turbulence->divRhoR(U) It is probably not used by you, because you have not selected a turbulence model that use R. Select the LaunderGibsonRSTM and let me know if you still think is is not used. N |
David Segersson
Rep Power: 6 ![]() |
I added a new solver to FoamX. The solver makes use of a scalar field called "landuse". When a new case is created, I would like FoamX to create a file for this field in the /constant directory (as it does with U, epsilon, k etc. in the "runtime" directory). I've tried to add and modify FoamX config files (looked at how the gamma-variable is handled in iterFoam), but get an error message in FoamX - "The create Case operation failed due to malformed boundary type definition dictionary for pressureInlet". What exactly does one have to do to make FoamX add a new field (volScalarField) when creating a case? The variable in question will not be solved for, so the boundary conditions is not so important. It would be ok with zeroGradient, or fixedValue everywhere (I have tried this in the windFoam.cfg file ("windFoam" is the solver name)). If anyone could give me advice on this, it would help me a lot. Thanks |
Mattijs Janssens
Rep Power: 13 ![]() |
I am not sure whether FoamX allows you to put a field in the constant/ directory.
See if it works if you use a different boundary condition as default - maybe there is something special with the setup for pressureInlet. |
| Thread Tools | |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| User Defined Pressure Boundary Condition | Evan | CD-adapco | 4 | February 2, 2009 04:09 |
| About FoamX | ivanyao | OpenFOAM Installation | 2 | September 21, 2008 21:24 |
| Run FoamX | ghazi | OpenFOAM Pre-Processing | 7 | July 9, 2006 14:48 |
| User defined scalar boundary condition | Philip | FLUENT | 0 | September 19, 2005 04:09 |
| User Defined Non Reflecting Boundary Condition | Tengc | FLUENT | 1 | November 17, 2004 13:58 |
