compressibleInterFoam p and U BCS
Old   May 23, 2017, 21:18
Default compressibleInterFoam p and U BCS
cherry
wangcc is on a distinguished road
I have used the totalPressure for P inlet, fixedValue for P outlet and PressureInletoutletvelocity for U inlet and inletOut for U outlet. But the solution shows that the maximum velocity in the field continuously decreases and eventually the minimum pressure continuously increasing. I have tried other BCs combination, but they don't work. Could someone give any suggestion on the BCs for commpressble two-phase flows?
wangcc is offline   Reply With Quote
compressibleinterfoam bcs
How to set BCs programmatically incompressible OpenFOAM Programming & Development 6 November 20, 2017 02:47
chtMultiRegionSimpleFoam: inconsistency between BCs and results Diro7 OpenFOAM Running, Solving & CFD 1 March 2, 2017 04:36
Difference between HF and Temperature BCs Catthan FLUENT 0 August 7, 2013 05:59
Dealing with BC's in OF 1.6 vkrastev OpenFOAM Running, Solving & CFD 5 September 4, 2012 11:58
Understanding Code behind BCs Linse OpenFOAM Programming & Development 8 January 9, 2012 08:58
