-   OpenFOAM Pre-Processing (http://www.cfd-online.com/Forums/openfoam-pre-processing/)
-   -   BC type (http://www.cfd-online.com/Forums/openfoam-pre-processing/66264-bc-type.html)
Khelian973 July 10, 2009 03:19
BC type
Hi foamers,
I have a stupid question but i dont know the answer. I have an interface between a solid and a fluid, considered as a wall.
What is the "type" to implement a simple wall, allowing the heat flux of temperature, in both side. "ZeroGradient" is for adiabatic wall i know. "fixedValue" doenst fit. I uses the type "calculated" but im not sure.
There are solidWallTemperatureCoupled or solidWallHeatFluxTemperatureCoupled but im not understand exactly for what case these both patches are necessary.
Thanks for helping me
SIncerely
Kyian
gschaider July 10, 2009 05:10
The first question that comes to mind is: Which solver are you using? Any further discussion depends on this. And please be more specific in the title when you start a new thread. For instance "BC Type for Heat Flux". BTW: if you search for that phrase you will find some threads that might be of interest for you
Khelian973 July 10, 2009 05:49
Hi Bernhard
Sorry dor the tittle :(, i will try to be more specific next time...
Im using the solver chtMultiRegion foam. I have a hot fluid in a pipeline and I want to study the impact of the heat transfer from fluid to the solid.
I've read some thread about BC for heat flux but it's usually to have a fixed heat flux. It's just a simple interface between a fluid and a solid allowing heat transfert
gschaider July 10, 2009 07:55
Originally Posted by Khelian973 (Post 222220)
Hi Bernhard
I never worked with the cht-solver so I'm afraid I can't help you there. Sorry.
